Results 1 to 13 of 13
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    DV relocation question
    I picked up a forge DV and I am considering relocatng it when I install it but I am unclear on one thing. I understand the DV installs in the TBB with the T fitting. But the hose coming off of the dv in some write ups goes to the air box, and others the TIP. Shouldn't it be the airbox? Any help is appreciated. I'm not positive I will be doing this but if I do I'd like to do it right....
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Sep 12 2007
    2001 Audi A4
    Re: DV relocation question
    Into the TIP after the MAF. That is what the ecu is programmed for.
    B5A4 Disco Potato!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Going into the air box would be exactly the same thing as running a BOV.
    Nov 19 2005
    WA
    Wouldn't it be the opposite? Since metered air would be flowing back through the MAF?
    As for the relocation part get a 1" ID hose and install it where the stock DV flows back to the TIP. It's a pain in the ass to get to however.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Aug 06 2008
    Indiana
    Ok guys, thanks just wanted to clear that up.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by bass_lover1 View Post
    The air being bypassed or "blown off" has already been through the MAF. You don't want it going through again, let alone at the higher temp than it was before it was pressurized.
    I relocated my DV down to the boost hose right off the turbo, instead of having the recirc line come up to the DV in the TIP, I have a "non pressurized" recirc coming off the DV to the TIP.
    Aug 09 2007
    Mount Airy, MD
    Quote Originally Posted by djwimbo View Post
    im slightly confused by what you did... any chance you have a picture?
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by SykoraA4 View Post
    I'll try to explain b/c I don't have any pics, and it's not worth posting online b/c it looks shady, but works amazing.
    Pre-Facelift cars have the DV mounted directly in the TIP. The DV is fed by a foot long donkey-dik looking hose(pressurized)
    Facelift/DBW cars have the DV mounted in the boost pipe right off the turbo, before the steel cross pipe under the radiator. The hose that recirc's the air isn't pressurized.
    I basically changed mine from the OEM pre-facelift design to the Facelift design.
    This was motivated by my A/C belt eating the donkey-dik looking hose, thus creating a boost leak from hell. I simplified the system and seemingly increased boost recovery during shifts.
    Aug 06 2008
    Indiana
    This is the "write-up" I found. Everything looks correct here? I priced this out today with parts I can get from work (Autozone) and I can do it for like $40 if I decide to.
    http://www.audizine.com/forum/showth...lve+relocation
    Nov 19 2005
    WA
    You sure about that? My 98's stock DV location was in the front cross pipe.
    Jul 07 2004
    socal
    Did you buy your car used? Could have been changed or it could just be the 97 and early 98 that came with the BPV up top.
    Oct 01 2008
    Philly
    yeah because my 99 aeb had the same setup as my 01..im pretty sure there all the same.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'll have to pay more attention to customer cars then. I could've sworn it was a prefacelift/facelift split.
