Results 1 to 11 of 11
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    bulb type for tail light?
    i have a tail light out, dash says right rear... Just want to have the correct bulb before i pull the light out. anyone know the watt/size/style i may need. I work at a honda dealer and feel certain parts will have the bulb i need, i just need to know what it is.
    B8.5 S-line prestige
    #fourringarmy
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    Re: bulb type for tail light?
    x2 my left rear is out..
    Mar 12 2008
    CHI-TOWN
    x3 left is out
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Almost any auto parts store has a book with bulb numbers in it. Or, just go on autozone.com -> shopping -> electrical & lighting -> input car info.
    Bulb #7528
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    My rear right is out 80% of the time, sometimes its not, should I replace the bulb, or could I have another issue.
    Sep 08 2008
    2005 A4 1.8QTip
    Williamsburg, Brooklyn
    Quote Originally Posted by passatkid View Post
    I brought my car to Audi Service last thursday to sort out this problem.
    They said that I indeed had a problem with the brake lights and that they fixed it.
    They also said that they found a problem with my brake master cylinder, so it is being replaced tomorrow.
    I suggest you bring it to the dealership if it is still under warranty!
    Sep 08 2008
    2005 A4 1.8QTip
    Quote Originally Posted by Mr.Audi View Post
    You can just pull the bulb out and take it to autozone / strauss and get a replacement for about 5~8 bucks.
    P.s.
    Sorry for the double post
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    my right rear is out too. i have a replacement bulb how do i get to the bulb?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    go to your local auto parts store , they'll usually have a guide book with your cars model / parts number. the bulb is honestly no more then $6
    installing the new bulb is really simple as well.
    open your trunk and locate where the tail light should be , you should find a half dollar circle. take a flat head and pull it out , that should reveal a ( + ) screw once you unscrew that gentle wiggle your tail light and the whole tail light should pop put.
    from there undo the tabs that connect the plastic lens to the internal bulb housing. that should give you access to the bulbs. (be careful sometimes the tabs can be brittle)
    (Look at the new bulb you should notice 2 notches metal base of the bulb)be careful when you pull out the bulb you need to have a small flat head to pry it out of the clip holding in the bulb.
    don't try twisting the bulb or pulling on it with force I can guarantee you you'll end up having a finger full of glass shards
    putting everything back should be pretty self explanatory.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    I think they are like 3 bucks from an Audi dealer, last time I was there and saw that when I was leaving a tech grabbed a bunch replaced the burnt on and gave me the rest.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    i got a right brake light for 6 bucks at the dealer and they installed it for me in no more than 2 minutes
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
