Results 1 to 10 of 10
    Jun 04 2008
    Oklahoma City
    major idling problem... please help :(
    Hey all. I hope I can get a few ideas.
    Here's the lowdown... I have an '04 A4 1.8T. I had a couple of the recirc hard hoses fall apart a few weeks ago. I replaced the factory elbow coming up from the oil cooler, and replaced the uber expensive zig zaging hardline with 5/8 hose, which seems to work just fine. I then replaced the puck thinking that it was causing rough idle. Still nothing. I've been up to the dealership (I know a tech) who read my codes with their expensive gizmos. I have P0300~304 (most likely because when it runs rough at idle) and P1297, which I can't remember the exact verbage of the code. Their troubleshooting tree is kinda useless for this code. It told us to do a check on the maf, an alignment on the TB. After checking the electronics, there doesn't seem to be any major parts glaring at us. It does say something about a mechanical recirculation valve, is that the DV? Anyways, I'm at a loss...my car doesn't run well, and I really don't want to throw money at parts hoping to fix it. I'm about to do the N249 bypass to see if that is causing any problems, but I'm kinda doubting it. I had a code for lean bank 1, which also seems to be a byproduct from it idling poorly. However, the Audi computer says that it's running 9% and 7% rich (WOT and idle, but i can't remember which is which). Can anyone help me out with ideas? I've only had this car for a few months and I'm ready to drive it off a cliff, if it would drive me there.....
    Thanks in advance for any help or suggestions.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Re: major idling problem... please help :(
    "mechanical recirculation valve, is that the DV? " That sounds like the DV to me. However, i'm not sure how it would be affecting your idle too much unless it's stuck open. Is it stock?
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    skimmed your paragraph quickly.. try unplugging the MAF yet?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jun 04 2008
    Oklahoma City
    Stock DV and yes, we unplugged the maf while it was idling and it didn't seem to make a difference. is there a way to test the dv?
    Oct 29 2006
    Vancouver
    Not sure how deep you are planning into modding your ride but that stock plastic pos bov should be replaced anyways.
    Another silver B6
    Jun 04 2008
    Oklahoma City
    Right now, everything is stock. Would the DV cause idle problems? I'm making boost at speed...
    Oct 29 2006
    Vancouver
    When, you did a search on "Idling", which diagnosis sounded the closest?
    Another silver B6
    Jun 04 2008
    Oklahoma City
    I've tried a bunch of things. If the car was running poorly at idle, and I unplug the MAF, would it get better or worse? When I tried this, there was no change, would this point to the MAF?
    Jun 04 2008
    Oklahoma City
    No other suggestions? Believe me, I've been searching this and other sites for a few days before I started posting. I didn't want to miss something easy.
    Senior Member Three Rings zcrew's Avatar
    Feb 15 2007
    2014 Tacoma
    Atlanta
    i'm going through a similar problem at the moment, except i haven't had it read by a nice scanner yet, just a cheapo autozone that said i'm running rich. i know one of my check valves its pretty busted looking, so i'll probably replace it, and maybe that will help. i'll keep you posted if i remember
