Results 1 to 9 of 9
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    What else do I need to make this work?
    http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK
    i know i need software, which company would work best?....i have injectors for APR 1+, would those work?
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Feb 17 2005
    Sarasota, FL
    Re: What else do I need to make this work?
    Damn, search ... easily 10-15 threads on this in the past 2 months
    Feb 17 2005
    Sarasota, FL
    And REVO, 430's or 550's, APR 386cc injectors will not work ... You also need all the supporting mods, exhaust, tp, FMIC, TIP, and a manifold to maximize the setup
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by A4ringedONE8T View Post
    yeah...i have exhaust, and tp is coming soon....FMIC is a lil out of my price range along with the turbo kit...would i be able to safely run this kit (not to it's full potential) without a fmic or would you recommend getting everything together then putting it on
    2003 A4 1.8T
    Feb 17 2005
    Sarasota, FL
    No, dont waste your time. Do it once and do it right
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    that was my thoughts
    if i can get $2k in my pocket...whats another $1k, right?
    2003 A4 1.8T
    Feb 17 2005
    Sarasota, FL
    GTRS $1,495
    Mani $300
    TP $150-200
    TIP $250-300
    FMIC $1k - 1,500
    Injectors $320-380
    REVO Stg 3 $699
    You will need between 3-4k by the time its done and running
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    yeah, you should really get all the supporting mods first. You dont want to put in the GTRS in first and THEN find out that you need a bigger IC or some other part to cope with the extra power. A4ringedONE8T said it best "Do it once and do it right".
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    don't forget the clutch!
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
