Results 1 to 4 of 4
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    %#*&@ combi valve!
    Pretty sure those aren't 5mm hex bolts... as mine have stripped like every damn bolt on my car so far. And yes, I had it fully seated before torquing.
    Anyway it even appears that my vice grips are slipping on the bolts. I have the kind that you can tighten further by socket wrench, really can't see how they are slipping.
    Anybody else struggle with removing this thing? I have ran out of ideas... too small of a space to bust out the dremel.
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Senior Member Two Rings KevinA41.8T's Avatar
    Nov 30 2005
    CONNECTICUT
    Re: %#*&@ combi valve!
    buy some quality tools. they're def a 5mm hex. try a snug fitting torx bit if you didnt damage it too badly already. also you can tap a 12 point socket onto the bolt.
    2000 S4 IMOLA - CCW CLASSICS 18X9 18X10 - STASSIS TRACKSPORTS 700/800 - ASP DTS - STERN MOUNTS - 034 DP'S - ASP TRU DUAL - CUSTOM INTAKE/CATCH CAN - VAST METH - AEM WIDEBAND - RS4 INTERCOOLERS - JFONZ TUNED
    Veteran Member Three Rings JustinCase's Avatar
    May 25 2007
    2013 A4, 2011 A4 Avant
    Scranton, Pa
    Mine came off without any effort at all. I just popped the hex wrench on there and it came right out. 3 minute job tops.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Feb 24 2007
    Burlington, Vermont
    yeah i got it easily this morning, I think I was just at my wits end last night
    - Scott
    Das Build Thread
