Results 1 to 12 of 12
    Sep 15 2008
    97 A4 1.8T Quattro
    huntersville, NC
    Question Cold Air intake?
    im thinking about buying for a cold air intake....
    so what would be the best bulk for my buck. im trying to keep it under or around $100 or so?
    i don't want a piece of crap, not really looking for one thats gonna drop my bank account?
    i have a 97 1.8t
    thanks guy!
    Oct 06 2004
    Minnesota
    Re: Cold Air intake?
    Don't do it unless your making over 300HP
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Like Rob said, it really will not increase your performance at all, im sure the stock airbox is designed to give you more flow.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jul 12 2007
    Massachusetts
    I got an EvoMs for 100 in the classifieds, and I didn't notice anything. The only thing you'll get out of an intake on a non-BT car is the spool up of the turbo. The modded stock airbox will be good for up to 300 hp, so don't waste your money.
    2020 SQ5
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    i got a k&n cold air from a local parts dealer and it costed me around 80$ but it really doesnt do anything for our cars, i just got it for the sound
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Oct 06 2004
    Minnesota
    Quote Originally Posted by TheWrightAudi. View Post
    Oiled filters are bad. If over-oiled they will coat the Maf
    Instagram r_michals
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    i completely took the back side of my air box off (cut it cleanly on the side that faces the wheel arch) but didnt cut the wheel arch like a lot of other ppl do, i value my car and we get a lot of weather up here in the northeast.
    I will be getting the 'true heat shield', s4 intake bellow and a AEM dry flow filter just to spiff up that side of the engine bay, not really looking to gain much.
    you could go that route and have roughly 120-130 into it total, if not less.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Aug 07 2008
    White Rock
    Quote Originally Posted by A4Rob View Post
    yea true but thats why ill just air it out with compressed air and never oil it and also if my maf is dirty i could clean it out with some electrical contact cleaner.
    cant be tooo bad for it..
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    I bought a Carbonio just for the clean look/sound of it. It was used local and I figured what the hell. I actually noticed a little bit faster spool time while flooring it in 5th on the freeway but thats about it.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Jan 17 2006
    Cali
    If you get a custom heat shield and an intake from boosted tech, it should make a bit of a difference. Only thing is, it's out of your budget range.
    http://www.boostedtech.com/products.asp
    Aug 09 2007
    Mount Airy, MD
    probably your best bet is to pick up a cone filter (k&ns are known to cause problems, however ive got one, i just make sure its not too oily), clamp it right to the maf, and make a heat shield, or buy the "true heat shield" being sold in the classifieds by a member on here. with that you get the "bov" sound (actually the diverter valve) and a slightly deeper sound, but no noticeable power.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    i have the AEM dryflow 5" with 2.75" fitting, stock maf, and the true heatshield from blinktekdesign.com. it is the official site of the guy that sells them on AZ. he does it as a favor to other Audi owners, so there is some lead time with it due to his work/family/hobbies. mine took about 4 weeks to get but it was SOOOO worth it. the dryflow is great cuz it uses no oil at all. you still have to clean it like any filter, but no oil to ruin maf and they say it has better particle filtering than a k&n. i didnt notice much of a hp gain but the sound is awesome. my mpg has actually gone down since i go into boost just to hear the DV. the heatshield works like a charm and is an easy install. it is a MUST if you go the cone filter route. 60 for filter on ebay. 100 for heatshield. totally worth it.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
