Originally Posted by
justinperkins
I'm still learning, so bear with me, but the headers you installed basically take the place of our headers+DPs, correct? I have seen people quote that piggies would yield about 10 HP and the same could be said for performance headers (that don't encompass the factory DPs), if you add them together then your 20-30 HP gain seems totally reasonable.
Yeah the exhaust tract goes like this stock (I highlighted problems with the stock setup):
The exhaust side of the heads ->
The stock log manifold (uses shared runners, unequal length runner, tubing inlets are smaller than head exhaust ports, small primary diameters, no real collector) ->
The stock downpipes (small 2.125" diameter?, 2 catalytic converters per pipe, tight bends and generally restrictive design, one of the catalytic converters is in the precat position immediately behind the manifold flange ) ->
The stock catback (small 2.125" diameter, center resonator doubles as a crossover less than ideal design, large restrictive mufflers, strange flattened section of piping before the mufflers)
The typical aftermarket fullback setup goes like this (advantages over stock in parenthesis now):
The stock log manifold ->
The aftermarket downpipes (larger 2.5" diameter, smoother bends, one catalytic converter per pipe instead of two, with some DP's [Fast intentions] the singular catalytic converter is located further downstream others have it in the precat position which is less than ideal)
OR
The piggie pipe (same as the stock DP just with either the precat or both cats removed) ->
The aftermarket catback (2.25" - 2.5" piping allows for greater exhaust flow [2.5" is preferable since it allows greater room to grow], smoother bends throughout the system, proper crossover design [x-pipe will allow for better high rpm exhaust scavenging], less restrictive mufflers and resonators, elimination of flattened section)
Finally there are the header cars:
The JHM longtube headers (eliminates the stock exhaust manifold and the downpipes combining them into one, larger primary diameters support greater high rpm flow and consequentaly high end power, equal length runners combined with a tuned collector design work to provide extra exhaust scavenging [I won't go into how this increases power it is pretty involved]) ->
As far as how exactly the headers help to create more power it is very very involved. Like I've said a million times header design is not some black magic of combining exhaust bends, trial and error, and chicken sacrifice; there are scientifically derived design parameters to follow based on desired power range and engine displacement. JHM did their homework and followed these guidelines exactly, and that's how they created a header setup that produces extra power in the midrange as well as the topend (they could've made a race header tha optimized power from 5k rpm and up, but chose to focus on 3k and up). So basically when they say it is a tuned equal length header, it means that the primary length and diameter, secondary length and diameter, collector design and length, and bend styles were all carefully chosen to bolster power in the midrange.
Some good reading over here btw
Performance Tune Questions
Piggie Pipes and CEL avoidance
