Results 1 to 28 of 28
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Test Pipe with stock exhaust.
    Anyone pimping the test pipe with your stock exhaust?
    If so, how does it sound?
    Any gains?
    Because I'm thinking of getting a test pipe, until I can order the magnaflow exhaust
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Re: Test Pipe with stock exhaust.
    no one?
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Three Rings d_maniac's Avatar
    Sep 16 2006
    99.5 A4 1.8T Q, 2004 A4 1.8T
    Bronx, New York
    in short i did that on my last a4 and you feel the difference and alittle more noise but you do notice alittle rattle from the mid mufflers
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    Are u stock or stageIII or what? I ran my stage III w/ a stock exhaust w/ a TP in for a long time and it felt great, added a little growl. I've put a test pipe on a customers car who was stage I and he too had a stock exhaust. It definitely changes the tone and you will notice it's slight gains. Get one
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Buncha motorcycles
    Memphis, TN
    I would do it... You will gain a little spool for sure and if nothing else your EGTs will g down and the car will cool down much quicker because the cat isn't holding all that heat in... My turbo and Mani used to glow bright red when I was stock now I'm running double the boost and it just gets a little red
    APR Stage 2/AWE Intake
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Im about to pull the triger on the VMR Test Pipe for the stock exhaust.
    Any objections?
    Stage 3 Forum Advertiser Four Rings VMRSport's Avatar
    Apr 25 2008
    Irvine
    You'll get gains. Of course, it'll be more noticable with a complete exhaust set up. However, at the same time, it's like, of course you'll also notice it if you got an intake as well, bored out valves, etc, etc. It just all adds up.
    -Don
    This box does not currently receive PM's. Please direct all inquiries to Charles (VMRWheels) or Peter (Peter@VMRWheels).
    B5/B6 Audi A4 Test Pipe w/ Heat Shield
    VMR Sport | Integrated Vent Gauge Kit
    B7 Audi A4 Test Pipe - $69.99
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Objection!!! haha
    i'd rather go 3" than 2.5"
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    lol
    im just woried about the sound
    i dont care about loudness, im worried about ricerness
    it prob wont be but just checking.
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    well the sound differences between the 2.5" and the 3" wont be much different, its more of a performance aspect. And don't worry about the "rice", the nice thing about a turbo is that it eliminates the ricey sound, or at least quiets it down a good amount.
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    In the case of a 3" on a stock turbo it will definitely give less performance than the 2.5, since the K03 on the stock mani doesn't flow that much and it's too little back pressure and may hurt spool. I would go 3" unless bt or higher. I will still be using a 2.5" on my bt setup since 2.5" is good for almost 400hp of flow.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I have this setup...its sucks, lol
    When you let of the gas after putting the engine under load, there is a nice, annoying rattle/rasp
    -Sami-
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Quote Originally Posted by Killerteve View Post
    So you would still reccomend a 2.5" TP over a 3" with a Stage 1+ tune and APR TIP?
    Can you confirm that the 3" gives less performance than the 2.5" on a K03?
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    I did, got the one from VMR too. Quicker sool, and a louder spool and also at idle it sound louder.
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    alright, i guess the verdict is yes
    ill call my friends shop and tell him to order one for me.(i dont have paypal, or a credit card for that matter) lol
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Quote Originally Posted by eurogruppe View Post
    The 3" will give you better top end tho, which is all that really matters to me since thats where my car needs improvement
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    For someone with a turbo as their avatar, I'd expect you to know a little bit more about the air dynamics involved with them. Backpressure is not a factor, N/A, turbocharged or otherwise. Backpressure is always bad as it creates a negative restriction. Now Velocity, that is where it is at. A smaller pipe will have a higher air speed than a larger one, within reason. Too small and you WILL get backpressure that will hurt your spool time and high-end delivery. Too large and the exhaust system will not help pull the gases out via scavenging which you might notice prior to the tubo spooling up but not too likely. With a turbo car, this isn't much of a factor due to the high speed, the turbine wheel presenting a partial obstruction already and the increased heat which can increase air velocity if kept INSIDE the pipes (heatwrap, etc).
    That said, with a K03/K04, you likely wont see an issue with the 2 1/2" or 3" unit. If you consider a GTRS or others in the BT breed; 3" is the definitive answer.
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Mar 12 2008
    CHI-TOWN
    i was in the market for a test pipe to and wanted to get a 3 inch due to the common thought that bigger the better but after reading all of this i decieded to go withthe evolutions racewerks tp cuz its a 3'' start and reduces to a 2 1/2 so u still get the best of both ends havnt installed it yet tho cuz i am planningto get it installed as i gret the rest of the exhust cuz i am worried about cross threding my bolts then i will be in worse shit so but look intothe
    Evolution Racewerks test pipe i belive its like 180 or 200 but i got mine for whole sale
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    ^^try using a period at the end of a sentence. i can barely understand what you're saying.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Installing my VMR test pipe on my stock exhaust today.
    Ill let you all now how it goes.
    Veteran Member Four Rings traf818's Avatar
    North Hollywood
    I had a test pipe and stock exhaust with my GTRS a long time ago and it kicked ass, but as soon as i stepped up to a neuspeed exhaust i noticed a nice gain in power.
    -Ralph
    F10 550i M-Sport
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    cool!!
    Exactly what I have been looking for!
    And Trev I'm looking forward to hearing your comments about it.
    Nov 25 2007
    All done!
    Let me start off by saying, what a PITMFA!!!
    Ok, don't let that scare you lol.
    The bolts came out with little effort, the hard part was trying to get at them..... I used PB Blaster which worked amazing. It freed up the nuts and bolts really well. Just so you know im TIP, i think its easier for the 5spd guys.
    As for performance i think i noticed a bit of a gain. I'm also not used to my car yet. I just installed a FMIC last weekend and got my car chipped with apr 1+ on Thursday.
    For sound its hardly any louder, maybe a tiny bit in the higher rpm's. There is a little bit of a noticeable rasp (that's the only way i think i can enplane it) under load.
    All and all im quite happy For the $100 i spent on the pipe its well worth it.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by Trev View Post
    If you have any way of getting a sound clip of the car now I'd be very thankful.
    DG '02 A4 1.8TQM
    My Build Thread
    Nov 25 2007
    I wouldn't.
    Its not that noticeable. Maybe if i had professional sound taking equipment.
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Thanks trev.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    When I installed mine, many moons ago. I had a 3'' on stock exh. Just a tad louder, nice little rumble at idle, and gained about 500rpms of useful power up top.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
