Originally Posted by
AudiMike
Ok cool is there a certain label I should look for? Like your Bi-Xenon... ones? I'm pretty new to this changing headlights thing so im not sure what exactly im looking for in housings for my situation. Any reccomendations to look for within the classifieds?
There are single xenon and bi-xenon housings. Both kinds also come in two versions, the US version (DOT) and European version (ECE/E-Code). Bi-xenon housings are always grey inside, however single xenon housings are either grey or chrome inside (like your current halogen housings). Just look for the description, the seller must specify if the housing is for xenon (HID) or halogen. You can easily recognize the difference between DOT housings and ECE housings when you look at the turn signals. ECE/E-Code housing turn signals are round, and DOT turn signals are oval with an orange reflector on the side, something a lot of people remove (that's the clear-corner mod). Here is some more information:
http://www.lltek.com/PRS_bin/PRS_69_...sts_claire.htm
What you want is either one of these variations, sorted by popularity:
E-Code single xenon housings (grey inside)
E-Code Bi-Xenon housings (grey inside)
DOT Bi-Xenon housings (grey inside) <--- I have these
DOT single xenon housings (grey inside)
E-Code single xenon housings (chrome inside)
DOT single xenon housings (chrome inside)
Just FYI, Bi-Xenon projectors are not brighter, despite the larger 3” lens (single xenon lenses are 2.5”) Their only advantage is superior high beams, since the low beam projector is also used as high beam (the cutoff shield flips down) but the high beam reflector is still there and works, so it’s basically two high beams. Bi-Xenon doesn’t mean better in terms of low beam light output, and actually, many people prefer the projected pattern of the single xenon low beam, but it isn’t any brighter, just more uniform and not as textured as the Bi-Xenon low beam. The grey/chrome finish on the inside of the housing is obviously personal preference. Also, other than the turn signal, there are two additional important differences between E-Codes and DOT housings. First, E-Codes have an additional bulb, a city light, and it’s located in the bowl of the high beam reflector (single xenons have it bellow the halogen bulb, bi-xenons have it to the side, near the projector). Then there is the lens, DOT lenses are always Fresnel type lenses, that appear to have circular grooves etched inside the lens (in reality the lens if fused from two parts, and the grooves are angled steps). E-Code lenses are for the most part crystal clear, however I have seen E-Codes with Fresnel lenses before, especially the bi-xenon kind. Basically, the grooved lenses make the cutoff look a little fuzzy and allow for a small amount of light to bleed above the cutoff line. The clear lenses make the cutoff appear very sharp and overall the clear lenses make the beam pattern appear brighter and more defined, which is usually very desirable.
All xenon housings use D1S HID bulbs, except for few rare examples (early 2002 models) that use the older, more common D2S kind, however the projector itself is identical, only the bulb holders are different.
