Results 1 to 9 of 9
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Will these work?
    I want to go Stage 1+, will these injectors work?
    http://www.034motorsport.com/product...ducts_id=17564
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    Re: Will these work?
    ha for stage 1+?? of course not unless you want to run super rich.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    ok?
    which injectors work, that wont set me back alot?
    Jun 08 2007
    GLI
    Orlando, Fl
    TT225s.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Veteran Member Four Rings AudiA4Style's Avatar
    Feb 24 2004
    B8.5 S4 l 75 CB550 Cafe Racer
    Quote Originally Posted by A4Dit View Post
    TT225s.
    or Siemens 380cc you'd want to stay within the 380-386cc.
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Ive been thinking about getting the 386cc TT225s. Is it ok to run those on a stock engine before a +1 flash? Im assuming that they would net me some hp gains before the flash also.
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    typically you install them just before getting flashed as to not get raped for an "hour" of labour, and so that you don't eff your car up on the way to getting flashed.
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by numer24 View Post
    No, they will not net you any gains. Your car will run worse with them. As for which injectors, go with whatever the tune was designed for.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    your just going to run very rich since the ECU is not compensating for the extra fuel = it'll run like shit.
    get a set of TT225 EFIs and just wait until you can get the flash, swap them out in the parking lot of the shop and then get your flash.
