Results 1 to 30 of 30
    Dec 06 2007
    Wink BT Tiptronic Video thread
    State setup and how much power if possible and place vids.
    this was the only way i could think of to call RLB6 out.
    this is a dual lol.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings J3RR3L's Avatar
    Dec 10 2006
    2003B6A4
    Re: BT Tiptronic Video thread
    LOL.. you are always on the fence about going BT
    Just pull the trigger
    Maestro GTX3071
    Senior Member Two Rings starfriend's Avatar
    Oct 17 2007
    A4 GTRS
    Norway
    just a heads up, go big or go home, by that i mean bigger than the gtrs :) i was stupid enough to go with the gtrs, now that was a slap in the face
    A4/B6-2001 [Eurospec]
    430cc Genesis //GTRS// REVO //ATP// CUSTOM 3" EXHAUST w/ Magnaflow Mufflers //BSR OPTIFLOW INTAKE// FORGE SPLIT-R //Neuspeed Xtreme TIP// Racetec FMIC //Hitachi E//
    Dec 06 2007
    i'm going to do it, but i wanna see the tach and the speedo flying.
    -Kirk
    Oct 17 2007
    A4 GTRS
    Norway
    its not flying at all, it is really not much different from a good chip, imo.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You may want to figure out exactly what went wrong with your install...I would be happy to walk you through it...
    I make quite a bit of power with my setup (over 300AWHP) and so do many others.
    My email is [email protected] and my AIM is gsfowler if you want it.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Quote Originally Posted by starfriend View Post
    wtf, are you on crack? a gtrs is WAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYy faster than a chip. If you have one and think your car is barely faster than a chip then you have a SERIOUS problem with your car. A gtrs will put bus lengths on a chipped A4. I went from APR 1+ to GTRS and about shit myself the 1st time I went out for a run and that was with it at only like 18psi and timing 2 when I normally ran 21psi and timing 5 (before getting meth injection) which makes a big difference. Then with the meth and running timing 9 it is another big difference over timing 5.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Yeah, my car is twice as fast as it was so I think something is wrong with your setup
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Oct 17 2007
    A4 GTRS
    Norway
    car seems to run perfectly fine, tho to me, it feels like a chipped car.. only that a car comes a lot faster (like 2200rpm), and mine hits 1.5bar @ like 3.8-4k. Im still on stock timing and boost ecu wise since ecode screwed me over for a SPS (hey, thats 349$ bucks ill never see again:p) ffs, a 320 bmw can keep up with me at 0.9bar (default boost from ecode) -- using a MBC now to run @ 1.5
    Dec 06 2007
    ^^ya u need to do something cause i can eat up a 320 with a chip and injectors.
    -Kirk
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I told you I would send you my SPS3 and help you dial in your car...
    You can sit here and post on the internet and whine like a little baby or you can accept some help and get your car running correctly.
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    With stock boost and timing, and saying that it's not much faster than a stage 1 car, I would say you're probably not even getting over 220wph. Either way that is still a lot more than a chip, and you are admittedly not running your setup even close to its potential. Quit complaining and get you setup tuned and you'll add at least another 40 at the wheels.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Jul 11 2008
    Illinois
    Wednesday night. I promise! I have to get 200 more miles on this clutch!
    Anthony
    Dec 06 2007
    ^^can't wait.
    -Kirk
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by GTRS A4 View Post
    i thought this was a TIP BT car thread?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jul 11 2008
    Illinois
    Quote Originally Posted by sean1.8t View Post
    It is! But Kirk is a sucker for any BT video
    Anthony
    Dec 06 2007
    ^^true that. shift real fast so it sounds like an auto lol.
    -Kirk
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    once we get this thread starting to fill with videos the links should be pulled out and added to the orignal post since this thread is already 17 (18 now) posts long and not a single video yet.
    Mine will be coming soon, I found a small boost leak last weekend on one of my IC couplers and it feels much more solid when it pulls now. i know i said i was going to have new logs and videos a week ago but they are on their way, just got delayed.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Why am I getting called out?? Like I stated before, I need to find my headrest mount if not, the only thing I can provide is a handheld sessions which will be shaking as shit!
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Dec 06 2007
    that's it we are starting a donation fund to buy RLB6 a headrest mount LOL.
    first bid $20
    -Kirk
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    krik why the hell are you always selling gangster ass rims.
    lets make a new fun... clean rims for kirk fun... that he can sell for his GTRS. haha
    Sep 20 2006
    MD
    Quote Originally Posted by AudiA4Turbo22 View Post
    first bid $20
    Well, I'm not wasting time looking for it anymore. I just ordered another one today and should get it by thursday, according to the shop I purchased from.
    Jul 11 2008
    Illinois
    Why do you need a headrest mount?? Your a TIP! I can take a video and I'm a 5 speed
    Anthony
    Sep 20 2006
    MD
    If I'm going to do it I would rather do a better job if possible. Holding the camera in my hand is not doing it better.
    Dec 06 2007
    Once again calling RLB6 out it has been 6 months wow.
    -Kirk
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    haha kirk at it again!
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Why are you calling him out? you just want to see a vid of him making power? haha
    My car is hardly tweaked to it's potential and I would say it's fairly quick... once I can start logging and tweaking im sure it will be as fun as RLB6 says it is...
    789whp
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    if somebody mails me their video camera I'll take all the GTRS video you want haha. It's a 6-speed, but I know you'll fall for any type of BT
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    LOL
    Kirk talking about going BT for the last 6 months...
    Dec 06 2007
    ^^actually going to happen like in a week, i was going widebody, but steered away due to the fact that i'm still in school and too much attention in the parking lot.
    -Kirk
