Results 1 to 6 of 6
    Aug 17 2008
    2002 Audi A62.7T Quattro
    Freehold, NJ
    A/C Stuck in Econ Mode - 2 codes - Please Help!!!
    Hey every one,
    Ok, so we have a 2002 A6 2.7T Quattro. About 3 days ago the A/C just stopped working properly, all of a sudden it has gotten stuck in the Econ Mode leaving us Hot and Sticky inside the car. I can sometimes get it to work by turning of the car and restarting. The buttons are not stuck down, all fuses are good.
    I have 2 codes in the Climate Control and they are:
    24.02
    23.12
    I have searched high and low for what they mean and can't find anything. Anyone have any idea as to what they may be pointing me towards and have any ideas how I can fix this issue so we can stop sweating?
    Thank everyone!
    ~Joey
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Re: A/C Stuck in Econ Mode - 2 codes - Please Help!!!
    I don't know if this is correct , but found those in the repair manual
    24 Cycling of the switches, absolute non-fluctuating
    23 Cycling of the A/C Refrigerant High Pressure Switch (F 118)
    Aug 17 2008
    Freehold, NJ
    Quote Originally Posted by audifirst View Post
    Yeah, I found the same thing shortly after typing this thread and I was thinking the same thing. I am going to guess that the High Pressure Switch is probably bad. I haven't gotten the Bentley Manual yet, I have to order it today. Can you tell me if R/R of the High Pressure Switch requires the refrigerant to be drained and recharged?
    If so I'll just take it in, if not I'll climb under there and do it myself.
    Joey
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    The pressure switch at the condenser is on a pressure tap with a valve core, you should be able to disconnect its lead, loosen it and then spin it off quickly, this will minimize your refrigerant loss, if you loosen it and begin to spin it off and the refrigerant does not stop leaking out you have no valve core , thus the entire charge has to come out. I haven't run into one yet without the core, GL
    Ryan
    I don't think I care anymore
    Senior Member Three Rings parm104's Avatar
    Jul 06 2005
    2009 Audi A4 3.2L Quattro
    Vancouver
    Does anyone know if this issue is covered under CPO?
    Apr 18 2007
    ny
    Quote Originally Posted by parm104 View Post
    It should be.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
