Results 1 to 4 of 4
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Well theres your problem! +part # needed
    So I pulled my door apart, hoping that the horrible crunching sounds of the broken regulator was the cable running along the plastic piece. Really was hoping I could repair the plastic and slap it back together. Obviously not.
    When I took the motor off, I found that the cable had actually gotten completely out from behind the white wheel and got in between the motor gears and the white wheels gears. Luckily no teeth broke or stripped.
    Is this the correct part # I need? 8E0837461C
    Genuineaudiparts.com comes up with 4 listings for that part number, 2 a4 and 2 s4... I'm guessing every one of them is the same. They really need to add pictures to the parts.
    Looks like I'll be getting a sweet birthday present
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Re: Well theres your problem! +part # needed
    I think I may have same problem.
    Is getting to it hard?
    Feb 24 2007
    Burlington, Vermont
    not at all, flat head screw driver, Philips screw driver, t25, 30, and 45. Really easy.
    http://audizine.com/forum/showthread...ndow+regulator
    - Scott
    Das Build Thread
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by Molotov View Post
    Thanks, free bump for you
