Results 1 to 28 of 28
    May 17 2008
    Montreal, QC
    Exclamation RS4 Exhaust = No Fit! Go Straight or No Go?? Urgent!
    Folks, your opinions and suggestions are needed
    I picked up an RS4 exhaust from a friend who swapped his with an aftermarket one. My 1.8T is in the garage now on the lift.. Stock exhaust is removed to put on the RS4 exhaust (with custom modifying the rear bumper openings)
    I know am not going to get near the RS4 exhaust tone,, however, the looks of it are sharp and i wanted to get it..
    PROBLEM!
    The RS4 mufflers are HUGE such that it interferes' with the Spare tire by 4 inches on each side!! taking the spare out and cutting where the mufflers need to go is a big job,, and i am not considering this as an option.
    Mechanic's possible solutions:
    1. Run straight exhaust (while keeping the stock Cat. but no mufflers) and attaching the RS4 tips. This will be done by running a Y pipe at the begenning of the exhaust, and a Y pipe at each tip in the back.
    2. Weld back the original exhaust, chop the tips off and put RS4 tips (where one of the internal openings of the RS4 tip will be a dummy)
    3. Do nothing. (Weld the original exhaust back)
    I am confused now, I really want that RS4 rear tips looks in the back.. however, I am worried that car will sound like a fart-can having Straight back exhaust.
    Suggestions ?
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: RS4 Exhaust = No Fit! Go Straight or No Go?? Urgent!
    Go with #2
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    May 17 2008
    Montreal, QC
    that does sound like a plan.. what pisses me off is that I wanted the blenty room for flow such that when I put the K04 turbo and bigger injectors,, i know flow will not be restricted in the exhaust.
    Will it be a good idea to run Stock exhaust with High-Cat for the K04 turbo and not have much flow restrictions?
    May 17 2008
    Montreal, QC
    I guess the question is, Does 1.8T Q sound like a fartcan with a Straight back exhaust ??
    His suggestion is,, we make it a straight back exhaust now, if its too annoying/lound/noisy/cheap.... we add aftermarket mufflers to it (i.e. Borla)
    Sound like a plan guys ?
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Sounds good to me. That's probably what I would do.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    May 17 2008
    Montreal, QC
    I think I will go with straight back exhaust since the car on the lift now and add mufflers as soon as I put my hands on some (Borla, remus.. )
    Question is:
    Shall I run it straight back on RS4 piping (2.5" to two 2.25") or stock 1.8T piping (2.25" or 2" to two 1.75") ?
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    RS4 piping
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    May 17 2008
    Montreal, QC
    Keep the RS4 resonator too?
    So basically,, a Y pipe after Downpipe.. connect to RS4 exhaust... RS4 Resonator... straight pipes .... a Tiny Y-connector at each RS4 tip.
    I hope the RS4 resonator will eliminate the fartcan noise.. (my fingers are crossed)
    Sound like a good plan folks ?
    Jul 11 2008
    Illinois
    What about some sort of aftermarket mufflers? It will be a bit noisy if you don't run ANY mufflers at the back
    Anthony
    May 17 2008
    Montreal, QC
    well you see.. the plan was that RS4 is gonna fit.
    Now that the stock exhaust is cut and on the floor.. i got no time to put on any aftermarket mufflers.. however, i will request that, but i dont think it will be possible now
    so I will cut the RS4 mufflers out.. put a straight pipe in its place,, then replace it with two aftermarket mufflers.
    Jul 11 2008
    Illinois
    Ah ok. Good luck
    Anthony
    May 17 2008
    Montreal, QC
    any opinion as to which muffler brand run best with my exhaust configuration?
    Borla ? Milltek ? Remus ? or ?
    Trying to look online for a store that sells the mufflers only...
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Go with Magnaflow. They are inexpensive, easy to get, and have a lifetime warranty.
    May 17 2008
    Montreal, QC
    what do you mean by easy to get ?
    any source website on hand ?
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    My plans for my exhuast are apr downpipe. cut off short to a y pipe. dual 2" to borla turbo style mufflers. or n1's
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    May 17 2008
    Montreal, QC
    Update!
    The stock piping will run up until the start of stock resonators.. stock resonators chopped off... RS4 resonators and piping until start of RS4 mufflers.. mufflers chopped off and replaced with Dynomax mufflers (S style) connected to RS4 tips.
    I was hopping for higher-end mufflers.. (Remus, Borla, etc) but since time is limited.. am going with what we were able to grab immediately.
    I just read some reviews about Dynomax,, they dont seem too great. My fingers are crossed and awaiting to pick up the car in 2 days to try it out and hear how good or bad it sounds!
    will keep you posted.
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    Never heard the 1.8t straight pipe, but my 2.7t with the straight pipe sounds awesome. It is loud, but the sound is definitely not fart can. People think I have the 8 cylinder all the time.
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
    Buncha motorcycles
    Memphis, TN
    why would you try to put a v8 rs4 NA exhaust on 1.8t ? get a custom made or a aftermarket designed for our car?
    APR Stage 2/AWE Intake
    Apr 04 2007
    PHX, AZ
    Quote Originally Posted by sa3dos View Post
    PROBLEM!
    Take a hammer to it! Can you rotate the mufflers / or \ to make any room?
    Wouldn't larger RS4 mufflers make the 1.8T quiet down considerably? Throw some magnaflows on it.
    Paul Cordero
    [email protected]
    May 17 2008
    Montreal, QC
    I took the RS4 exhaust root because a friend of mine gave it to me (he didn't want it) so am taking advantage of it.
    The shop is putting Dynomax mufflers on... am going later this afternoon to check how the setup is going.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    *Route, I was confused for a bit as to exactly what a "Exhaust Root" was. LOL
    Silly Canadians, i woudl live there if i didn't love my job and could quit.
    May 17 2008
    Montreal, QC
    Quote Originally Posted by widgget View Post
    thanx for clrifyin (or *CLARIFYING) what it obviously meant, widgget
    Feb 12 2008
    whats the stock exhaust size on a 1.8t all the way back. quattro btw
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Watsup Sa3dos, i remember having a huge conversation about it on AF. Well, i'm still interested to hear the results, keep us posted.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Buncha motorcycles
    Memphis, TN
    stock DP is small like 2.25" i think
    Feb 12 2008
    so would a 3" to a Y pipe that splits into dual 2.5" be to large? im trying to price out exhaust pieces to build an exhaust. is 3" going to have not enough back pressure. i'm leaving the stock cat on for now
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ^^^ here is a good discussion on custom exhausts...
    http://www.audizine.com/forum/showthread.php?t=229681
    Established Member Two Rings adeelkhan323's Avatar
    Oct 11 2008
    Blackburn, UK
    Hi, guys,
    I managed to do it but had to modify both the exhaust and the wheel well.
    The wheel to fit the mufflers
    and the exhaust pipe to around the fuel tank.
    have a look
    http://www.audizine.com/forum/showth...ld-Diary/page5
