Page 5 of 6 FirstFirst ... 345 6 LastLast
Results 161 to 200 of 220
  1. #161
    Active Member Two Rings adeelkhan323's Avatar
    Oct 11 2008
    Blackburn, UK
    Re: AUDI A4 B6 to B7 RS4 Widebody Replica Conversion Build Diary
    Quote Originally Posted by DALLEONUK View Post
    hi matey new to this site love your work. Doing /trying to do a front end as you have from b6 to b7,could you do me a favour and answer a few questions like does the door lines line up to b7 wings and what extra bits i need apart from wings, bumper/grill,headlights and bonnet,many thaks dal
    The door lines won't match. There about 5 mm out. I've seen a few people cut the wing in half. B6 near the door and b7 near the headlights.
    You also need the front slam panel, i.e the part that holds the radiator.
    Also the front bumper reinforcment bar.
  2. #162
    New Member One Ring
    Jan 26 2010
    DONCASTER ENGLAND
    Quote Originally Posted by adeelkhan323 View Post
    HI AGAIN THANKS FOR THE RESPONSE,ARE YOU REFERING TO, JUST THE S4 WINGS AS THERE WIDER OR SE WINGS
  3. #163
    Oct 11 2008
    Blackburn, UK
    Hi, i'm referring to the A4 b7 SE wing and a4 b6 SE wing. If you cut it just infront of the wheel arch.
    The doors will be b6 and the back part of the wing next to it will be b6.
    the headlights will be b7 and the front of the wing will be b7.
    Hope that helps
  4. #164
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Figured this thread need a bump and to see if there have been any updates?
    USP CLUB MEMBER #127
    04 A4 B6 1.8TQ S-Line 190bhp 6 Speed DSMIC
    |B7 DTM Milltek| VMR Gauge| SP51 K04-15 Outlaw (K04-23+)| Samco Sport DV|034 Sport CAT|Auntbahn88 TIP| N75J|TT MAF|380 inj|
    2Do list:|B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB IV|RS4 custom SMIC|
  5. #165
    New Member One Ring
    Jan 26 2010
    DONCASTER ENGLAND
    Angry B6 headlight wiring to b7
    hi does anyone have a diagram of the wiring connector/or conversion from a b6 to b7 headlight having a night mare as wiring connectors are wired different
  6. #166
    Senior Member Two Rings parimal's Avatar
    Oct 20 2008
    Boston, MA / Danbury, CT
    I have them posted on my build thread....used them to switch the wiring around and it does work!
    http://www.audizine.com/forum/showth...ex-Rear!/page2
    '04 B6 1.8T B7 Front Conversion -Deval RS4 Front-Votex Rear-V708 18in-Helix B7 Leds w/ HID kit-CFCupra Spoiler-RS4 Sway Bar-H&R Sport Springs-Bilstien Sport Shocks, 10mm(F)/15mm(R) Spacers-Mid-muffler delete-Magnaflow tips-Magnaflow Intake-APR Stage II+-3" Testpipe, 225TT injectors-NGK Spark Plugs-Carbon Fiber Engine Covers and Interior Trim-Interior LEDs-Dynavin GPS-Rearview Camera-Hardwired Escort
  7. #167
    Oct 11 2008
    Blackburn, UK
    Thanks for this. will need it when i start to rebuild it all
  8. #168
    Oct 11 2008
    Blackburn, UK
    20 Weeks - It emerges from its grave
    Have been really busy working on the car so haven't had a chance to take any pics.
    Finished all the plug welds. Sanded them down smooth.
    Fitted the inner quarters and folded the outer quarters over the,.
    Covered all the welds with Zinc coating and the inner arch with Wax oil.
    Took it out as its going to get sprayed now.
    Got it half way up the ramp and it got stuck.
    But managed in the end.
    Click here to see the full project
    Click here to see the car
  9. #169
    Oct 11 2008
    Blackburn, UK
    THE BODY SHOP HAVE STARTED ON THE PREP WORK.
    QUITE A LOT DONE ON THE CAR.
    ONLY THE BUMPERS LEFT.
    LOWERED THE CAR AS WELL.
    PUT SOME KONI 50MM LOWERING SPRINGS ON IT FRONT AND BACK.
    DON'T KNOW IF IT I HAVE LOWERED IT TO MUCH, SO JUST IN CASE,
    I 'VE ROLLED IN/FOLDED IN ALL FOUR ARCHES. SO THEY ARE TOTALLY SMOOTH.
  10. #170
    Oct 11 2008
    Blackburn, UK
    TRIED FITTING MY RS4 EXHAUST TODAY.
    CAME ACROSS MY FIRST ISSUE.
    THE BACK BOXES ARE TOO BIG. THE RS4 DOES NOT HAVE A WHEEL WELL. IT HAS A BATTERY INSTEAD OF A SPARE TYRE.
    SO HAD TO MODIFY THE WHEEL WELL BY TAKING 3 INCHES OF EACH SIDE.
    THEN FABRICATE A METAL FRAME AND CASING TO FILL THE CUTOUTS.
    I'M GOING TO FIT A SUB IN THE WHEEL WELL LATER AS ITS TOO SMALL TO FIT A SPARE TYRE BUT BIG ENOUGH FOR A NICE SUB.
    THEN MY SECOUND ISSUE, AS MY CAR ORIGNALLY ONLY HAD A SINGLE EXHAUST ON ONE SIDE. THE OTHER SIDE HAD THE FUEL TANK.
    THEREFORE IT WAS EITHER CHANGE THE FUEL TANK OR MODIFY THE EXHAUST. I CHOOSE TO MODIFY THE EXHAUST IN TO A Y SHAPE RATHER THAN THE ORIGNAL V SHAPE.
    FITS PERFECTLY. HAD TO FABRICATE SOME MOUNTING BRACKETS.
    I ALSO TOOK OUT THE CENTRE BOX. SO ITS A STRAIGHT THROUGH PIPE FROM THE CAT TO THE BACK BOX.
  11. #171
    Oct 11 2008
    Blackburn, UK
    FITTED THE KONI 50MM LOWER SPRINGS
    FRONT
    AND BACK
    THE MODIFICATIONS I HAD TO DO TO THE WHEEL WELL
    SO THAT I WAS ABLE TO FIT THE RS4 EXHAUST.
    WELDED 3MM THICK METAL PLATES
    THE FRONT WINGS WITH THIER LIP FOLDED/ROLED IN
    THEN SEALED WITH STRONG ADHESIVE SEALENT
  12. #172
    Senior Member Four Rings fatbrembos's Avatar
    Sep 30 2009
    bmw e92 335/e36 m3/e46 m3
    Daytona Beach/Mexico/SP Brazil
    whats the idea for the final color?
    BUY MY 335i!
    Eurotuner A3 S-line -Sold
    07-e92 335i
    07-mkv gli
    11-v6 mitsubishi pajero
  13. #173
    Oct 11 2008
    Blackburn, UK
    Quote Originally Posted by fatbrembos View Post
    Hi, i'm doing it Pearl Sprint Blue.
    The cars been semi painted allready. Only the exterior to do.
  14. #174
    Sep 30 2009
    sweet man post some pictures when you get the chance
    BUY MY 335i!
    07-e92 335i
    07-mkv gli
  15. #175
    Oct 11 2008
    Blackburn, UK
    SNEAK PREVIEW
    Hi All
    Heres a sneak preview.
    Its SPRINT BLUE just looks a bit darker.
    Its still needs to be laquered/clear coat.
  16. #176
    Senior Member Three Rings coran nariman's Avatar
    Jul 06 2007
    toronto
    dambbbbbbb that looks very niceee
  17. #177
    Sep 30 2009
    i want!
    BUY MY 335i!
    07-e92 335i
    07-mkv gli
  18. #178
    Senior Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Great looking....
    A4 B7 1.8T 20v Quattro Project
    powered by ToM's Garage and Etuners
    Mike
  19. #179
    Oct 11 2008
    Blackburn, UK
    Quote Originally Posted by Doctor View Post
    Great looking....
    Watch this space, going to get all the glass fitted back in this weekend, so will have loads of pics.
    The cars still at the spray shop. Will be getting it back next week.
  20. #180
    Jun 02 2008
    Greece
    Seriously, cant wait for pics from this project. Awesome I love the work u put into it
    Mike
  21. #181
    Oct 11 2008
    Blackburn, UK
    Here's what it looked like just before it went in the spray booth
  22. #182
    Oct 11 2008
    Blackburn, UK
    This is what you've al been waiting for.
  23. #183
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    wow, good to see it coming together!
  24. #184
    Oct 11 2008
    Blackburn, UK
    Went over this weekend to have a look at the respray.
    While i was there i fitted the rear glass and rear quarter glass.
    Then the wiring loom for the doors and the door glass.
    I also attached the door selonoids to pop the doors open.
    Oh and the rs4 mirrors.
    Not bad for one days work.
  25. #185
    Oct 11 2008
    Blackburn, UK
    RS4 PROJECTOR LIGHTS JUST LANDED
    ONLY PROBLEM NOW IS HOW TO WIRE THEM UP.
    THE WIRING LOOM ON THE RS4 IS TOTALLY DIFFERENT TO THE A4
    I'M GOING TO USE SOME AFTER MARKET BALLASTS AND REWIRE THE WIRING.
  26. #186
    UK London
    You need an adapter lead, not sure what its called but im sure someone will step up.
  27. #187
    Senior Member Two Rings Billi's Avatar
    Nov 24 2007
    Norway
    I think Kufatec has some adapters, but I dont know if you had OE xenon on your old headlights..?
    I still have some FIS-warnings coming up on mine. Guess I need more resistance in the wires that goes to the fullbeam function.
    B7 only has a magnetic valve that lifts the lowbeam up to fullbeam, while the B6 has its own bulb.
    And I get a faultwarning on the up/down adjustment of the headlights... dont know why...
    Let me know what you fint out!
  28. #188
    Mar 09 2005
    Santa Clara, CA
    There are different wiring adapters depending on if you started with xenons or not, and if your lights are adaptive: http://kufatec.com/index.php?main_pa...ort=20a&page=2
    If this gets rid of your bulb out warnings let me know! I'd pick up a set myself.
    BTW, Billi- do you have a pin out of how you wired your tail lights up? Just a photo maybe?
  29. #189
    Oct 11 2008
    Blackburn, UK
    "Billi- do you have a pin out of how you wired your tail lights up? Just a photo maybe?"
    Hi yeah that would help me to.
    I've opened one of the lights and can see where all the wiring goes. I'm going to try wiring it without the kufatec adapter. If it works i'll right up a wiring diagram.
  30. #190
    Nov 24 2007
    Norway
    just buy the wire harness for RS4 trunk and splice the wires inside the car.
  31. #191
    Oct 11 2008
    Blackburn, UK
    Went to pick the car up to bring it back home.
    Mounted the modified rs4 exhaust back on the car.
  32. #192
    Jun 02 2008
    Greece
    The more I see this project, the more I KNOW, i HAVE to convert mine....fuck...
    Mike
  33. #193
    Oct 11 2008
    Blackburn, UK
    Got my car back home and started on it straight away.
    Front end all fitted.
    Small carbon effect front lip.
    Xenon lights fitted.
    Wired the front lights manually and have no error lights on the dash.
  34. #194
    UK London
    Dam that looks good, I may have to pick your brains on the lights
  35. #195
    Active Member Two Rings migsan's Avatar
    Mar 16 2007
    Audi A4 Avant B6 130cv M6
    Portugal
    Congrats!!! It looks very nice ... great job!
    Audi A4 Avant M6 130cv
    Color DIS, RNS-E, OEM BT, S5 MFSW, S4 B8 Gear Knob, RS4 B7 Alu Pedals, AluLook Interior Trims, Interior Auto Dimming mirror, Parking Sensors, S4 Front and Rear Bumpers, USP Roof Spoiler, FTM Side Skirts, S4 Bi-Xenon Headlights, Proline PU 18x8 ET35 Wheels, 2.5 TDI OEM Exhaust Line, OEM Headlight Wash System
  36. #196
    Jun 02 2008
    Greece
    Wow it looks awesome...
    Mike
  37. #197
    Sep 30 2009
    looks great man!
    what kind of wheels and brakes you planning on using?
    BUY MY 335i!
    07-e92 335i
    07-mkv gli
  38. #198
    Oct 11 2008
    Blackburn, UK
    Quote Originally Posted by docurley View Post
    damp that looks good, i may have to pick your brains on the lights
    no probs. Quite easy to do. I didn't use the kufatec kit.
    I did it manualy one wire at a time. I have it all recorded which wire goes where etc. Pm if you need.
    How far you got with yours.
  39. #199
    Oct 11 2008
    Blackburn, UK
    Thanks. Its taken me just under a year to get to this point
  40. #200
    Oct 11 2008
    Blackburn, UK
    looks great man!
    What kind of wheels and brakes you planning on using?
    i've got a set of genuine rs4 alloys in a smoked gunmetal colour. I've got pics of them on one of the other pages
