Results 1 to 15 of 15
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    CEL came on today...
    03 1.8T, 74,000 miles stock. Driving in to the office today at a red light my CEL comes on. Not blinking. Car has been running fine. Only thing I even remotely noticed was that sometimes while at idle it seems to drop in revs or hesitate for maybe half of a second. Other than that the car is mechanical flawless.
    Bringing it to autobahn performance in Peabody Mass at 1pm today. Not my usual shop, but they are less than a mile away from where I work.
    Any thoughts?
    Buncha motorcycles
    Memphis, TN
    Re: CEL came on today...
    throw a dart at a bentley and you have have the same chance of guessing whats wrong... just get the code scanned
    APR Stage 2/AWE Intake
    Mar 20 2006
    Quote Originally Posted by Papachristou View Post
    Yeah, but what I meant was to find out if anyone else is experiencing the same hesitation at idle for half a second.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by KPC1.8TQuat View Post
    Any thoughts?
    Could be a mis-fire. That'll throw a CEL.
    Is your valve cover gasket leaking around the spark plugs?
    How old are your coil packs?
    When was the last time you replaced spark plugs? What plugs?
    Original, factory, software? misfires are rare then, unless something is causing them like the questions I posed above.
    -Doug
    Mar 20 2006
    It's not a blinking CEL which is usually conclusive for timing or misfires
    No leaking oils anywhere.
    I just had my shop put in 4 new R revision CP's last April
    Plugs are Bosch +4's with less than 10k miles, not copper but I'm stock so no need.
    I really don't think it's a misfire. The car has normal power when it's not at idle. Like I said in my first post, the car is running absolutely fine. If not for the CEL, I wouldn't notice anything really wrong with her. My vacuum at idle is normally around 20mmHg but I'm noticing it's down to around 16-17mmHg once the car is warmed up. Could be a leak somewhere?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I would say........emissions related
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Not exactly true. I get (random and intermittent) mis-fires at cold start-up and its a solid CEL. [That's just because my tune is no where near what it needs to be right now.]
    -Doug
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    bad o2 sensor!
    I just wanted to throw a random guess out... just wait for the scan
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Mar 20 2006
    Just got my scan done.
    I don't remember exactly what he said, but something about one of the banks running lean. Most probably cause is a bad MAF, or a vacuum leak somewhere. Code was cleared and the car is safe to drive, only drawback until it's fixed is a slight dip in my fuel economy.
    Looks like a MAF party this weekend! WOOT!
    Thanks all.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    ^^^ Before buying new MAF, try to clean it. They sell those MAF cleaners at Autozone and etc. Also, there is a chance that one of the vacuum hoses broke. Check them!!!
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    I tried to clean my MAF and it didn't help, so I had to buy a new one. Worked great. ECS tuning!! Same symptoms except my car would actually die at a red light.
    Mar 20 2006
    Quote Originally Posted by coowhip View Post
    Yeah, I'm going to take a look at the MAF tonight when I get home and see what shape its in. I'll most likely just buy a new one.
    Thanks everyone.
    Dec 25 2004
    Earth
    People dont want to hear the truth!
    They want everyone to play their "CEL Guessing Game!"
    A prize should be offered for the most correct/nearest guess...
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Quote Originally Posted by aaaudiprotein View Post
    you can also use electrical contact cleaner to clean your MAF
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Thanks everyone.
    You wouldnt really see any difference if its dirty or not.
    Are u chipped by any chance? Open your hood while car is on and listen for any air sound. Also, when the engine is cold, try to look over all those vacuum/boost hoses.
