Results 1 to 9 of 9
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    VAGCOM port AWOL? Does running a piggyback system like my SDS kill it?
    I have the Q to the PO and the shop who did most of the work, but thought I would hit up the collective genius here.
    It's not under the dash nor behind the armrest. The hole is there, but no data cable connector. I could remove the lower dash panel to check, but if it is rendered useless, then that's that!
    Thanks guys.
    Bill.
    Dec 05 2007
    Re: VAGCOM port AWOL? Does running a piggyback system like my SDS kill it?
    Check the rear ashtray
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    should be some where in the lower dash panel, open it
    GIAC-X, STASIS TS,VAST,034 MS
    Feb 27 2005
    North Wales, PA
    there is a clip that holds it in. Sometimes if someone pushes too hard then it will pop back into the knee bolster.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    remove the knee bolster, im sure its there.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Feb 25 2007
    1998.5 A4 2.0BT
    Thanks everyone, some things came up that kept me from more playtime tonight (just borrowed a friends vag com system), I'll pop it open tomorrow and see where that thing is hiding.
    B.
    Oct 29 2005
    10speed
    San Francisco, CA
    its in there
    - Clint
    Aug 09 2007
    Mount Airy, MD
    if you dont want to pop off the whole knee bolster, just open the side where the fuses are and see if you can see anything.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Feb 25 2007
    1998.5 A4 2.0BT
    Thanks guys, pulled the fuse panel, couldn't see anything... dropped the bolster, it was tucked in the back. Pulled it out, put the bolster back, done!
    There sure is a lot of that fuzzy carpet stuff in there!! I am assuming it is fire proofing or at least fireproof with the power block and fuses... seems so strange to me.
    Now I have to figure out how to use zee Vag Com :)
    B.
