Results 1 to 11 of 11
    Dec 24 2007
    St. Pete,FL
    P0171...system too lean
    i have been throwing this code on and off for a month now and its on my last nerve....it threw it once a couple weeks after i went apr1+...erased it car was fine....next week i got my exhaust,TIP/intake, and removed some SAI "uselessness", new n75k, and new dv....drove home got the code again....erased it...came on but turned itself 2 days later for 2 weeks....now it is just on and wont go away unless i erase it....i have changed coilpacks and got one step colder plugs when i first chipped it to stage one.....after the codes i have changed the fuel filter ran seafoam through the gas tank to clean all that.....im guessing its o2 sensors bc it still idles fine which if it didnt would indicate a problem with the maf? i told the shop to load the testpipe file when i got the apr1+...could that be the issue??
    any help is appreciated and thanks in advance.....
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Re: P0171...system too lean
    do you have access to a vagcom?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Might be a vacuum leak. And most likely one of your (or more) check valves is done.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Sorry, I'm feeling lazy right now. Run a search on P0171, user name old guy. I'm sure it will pull up several discussions. Hopefully one will help.
    cheers!
    Dec 24 2007
    St. Pete,FL
    no access to vagcom.....i guess i should run a boost leak test...i have a spare check valve laying around
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by SmokdOutA4 View Post
    Open your hood and see if u can hear any unusual air noises. Also, try to look for any broken hoses visually while engine is cold (it would be much easier :)))
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    I had that code, then I found out someone installed a BOV and once I put the Forge 007 DV it, it cleared and never came back along with fixing a few vacuum lines and boost leak.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Im gonna say that is is most likely the MAF sensor. Mine did this with the same code. Would turn on/off, etc. If you want to double check before you buy a new one, get a vagcom, and log air mass readings under WOT.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    does your car happen to be an 02'?
    Dec 24 2007
    St. Pete,FL
    yah its an '02.....
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    More then likely a vaccuam leak, my o2 has the same issue
