Results 1 to 10 of 10
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Clunking/Binding noise.. Help
    so i recently took a little roadtrip down to San Diego and on the second day started hearing a clunking or binding noise coming from the front of the car.
    the noise only happens when i'm coming to a stop (like right before i actually come to a complete stop) or when i'm coming out of a stop at very low speeds.
    it happens with or without the brakes applied so i dont think it is the brakes. and it doesnt happen over bumps anymore that on flat ground...
    i'm gonna jack up the car but any input or things to look for would be great.
    P.S. the car is on stock suspension and stock wheels with 98k miles
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: Clunking/Binding noise.. Help
    prob an upper control arm, if you havent had one bad at 98k then consider yourself lucky
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    ya i bought the car with 95k and i'm not sure if the guy before me had them replaced. i'll check the records...
    anything else?
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    upper control arm or a lower control arm ball joint failure, check the condition of the bushings on all control arms aswell, once the rubber wears away, it is metal grinding on metal, not to mention your suspension falls out of alignment.
    ball joints can be checked by putting lateral pressure on them via a long wrench, and feeling the joint for abnormal movement. You may also want to check your wheel bearings, they will grind when they start to completely fail
    I had a failed ball joint for almost a year, it would make a very faint rattle/bump/grind noise at low speeds
    My car is fast
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    awesome thanks!
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    I had that exact same thing happening to my car and I thought it was my upper control arms as well. It turned out that my motormounts weren't tight enough from when my stage 3 setup was installed. They took about six turns on the nut and now that exact same sound that you are describing is gone. I would check to see how your mounts are as well as the control arms....
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    I wonder if thats my problem. I have changed all the control arms and still have noise..
    Dec 11 2006
    Orange County,CA
    ^^^I would check that boris, if it feels like a popping sound when starting and stopping then that would be a good place to look.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by audiwop View Post
    i never thought of the motor mounts, but that makes sense. i'm not stage 3 yet only stage 2 but i bet the same thing could have happened. thanks!
    Dec 11 2006
    Orange County,CA
    No worries...
