This is our own special Votgland setup you can't get them from anyone else! Our Votgland GT kit is a matched spring & shock kit on adjustable spring perches, so adjustable coil overs. This is a aggressive street kit, & not really a track setup. It's about 15-20% stiffer then stock. The ride is great, no more brake dive, no more acceleration squat, & much less body roll!
Since ride height is totally adjustable, you get to select your drop level, from higher to stock, to riding on the ground (highly not recommended).
Prices:
B5: Regular = $1,449; On Sale = $1,399; GB = $1,299
B6: Regular = $1,449; On Sale = $1,349; GB = $1,249
B7: Regular = $1,449; On Sale = $1,349; GB = $1,249
With code: AUDIZINE
While you are in there, might as well add our ASP trans brace. This really stiffens up the subframe & trans. You get 2 mods in one, much better shifting under power & drivetrain alignment, with the added bonus of sharper turn in with a more crisp steering feel. Almost a must with stiffer suspension
We offer the whole ASP line! Our downpipes are inside & outside ceramic coated in Titanium, our ASP FMIC has a heat dissipating coating that give lower IAT's for more HP! In your choice of color.
We also do on site REVO flashes & custom tunes. 15% off if you purchase a REVO select switch with your flashes.
This will go on for 2 weeks, or until we run out of current Votgland stock, but we just received a 1000lbs shipment!
FREE SHIPPING ON ALL ORDERS in the US.
only 2 B5 kits left
Only 1 B6 & B7 kit left!!
GB ends on 9/12!
