Results 1 to 13 of 13
Thread: SPS3
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    SPS3
    Can't find any good information about this...
    How do I upload new settings?
    I've tried the following procedures..
    1
    set it to mode 4 (high boost) then setting *
    key in ignition turned to "on" position
    plug sps into port
    single beep occurs
    remove sps3 and start car
    2
    plug sps into port
    single beep occurs
    remove sps3, key off, then start car
    3
    plug sps into port
    single beep occurs
    key off, key on
    4
    plug sps into port
    single beep occurs
    key off, key on, key off again
    Think somebody sold me a defective one or am I just an idiot
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    Re: SPS3
    did you just buy the sps3? because you need to be flashed as well the sps is only for going throough pre-set programs but if your not flashed it wont do anything
    Feb 24 2007
    Burlington, Vermont
    Re: SPS3
    check sig
    - Scott
    Das Build Thread
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: SPS3
    Boost is mode 3. Timing is mode 5. Didn't it come with an owner's manual?
    To get the settings uploaded:
    -turn the key to the on position
    -plug in the sps3
    -turn the car off after it beeps, I usually wait for it to beep 3 times
    -remove the sps3
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: SPS3
    Link to the instruction manual.
    Instructions
    1. Locate the OBD-II port.
    Refer to owner’s manual.
    2. Turn ignition on, wait 10 seconds.
    3. Select setting on SPS.
    4. Connect SPS to OBD-II port.
    5. SPS will start beeping after a few seconds.
    6. Remove SPS when beeping is active.
    7. Repeat steps 3-6 as desired.
    8. Start engine.
    SPS3 modes
    Mode 0: SPS inactive.
    Mode 1: Stock mode.
    Mode 2: Performance mode enabled.
    Mode 3: Boost adjustment
    Mode 4: Fuel adjustment
    Mode 5: Timing adjustment
    Modes 6-7: Not used
    Mode 8: Anti-Theft Enabled.
    Mode 9: Anti-Theft Disabled.
    Vario Range Guidelines
    DBW (drive by wire)
    Mode 3 Boost adjustment:
    Range 0: Valet mode.
    Range 1: Stock Boost.
    Range 6: Performance Boost.
    Range 9: Aggressive Boost.
    Mode 4 Fuel Adjustment:
    Range 0: Stock Air-Fuel Ratio (AFR).
    Range 9: Performance AFR.
    Range 9 is the default performance setting. The fuel
    adjustment is not available on all cars. Please refer to
    our additional tuning guide for more information.
    Mode 5 Timing Adjustment:
    Range 0-3: 95 Ron or 91 (RON+MON)/2 octane fuel.
    Range 4-6: 98 Ron or 93 (RON+MON)/2 octane fuel.
    Range 7-9: unleaded race fuel, octane over 100.
    Feb 24 2007
    Burlington, Vermont
    Re: SPS3
    alright thanks, the instructions I got in the box said nothing about waiting 10 seconds, that's probably my problem
    - Scott
    Das Build Thread
    Feb 24 2007
    Burlington, Vermont
    Re: SPS3
    ps, the instructions also said mode 3 was low boost and mode 4 was high boost, I had been changing them both to 8 as I didn't know why there were two boost settings.. so that's not the initial problem with what I've been doing.
    - Scott
    Das Build Thread
    Feb 24 2007
    Burlington, Vermont
    Re: SPS3
    so a little update. Went out on my lunch break and tried the anti theft (mode 8). the car stalled out almost immediately on startup, proving that the sps works, turned anti theft off and it started up fine.
    NOW - I've used mode 2 to turn on performance mode, and set b to 8 and t to 4 the same way that I had turned on and off antitheft... it made no difference, boost spiked at 19psi still (could actually be a boost leak, doing more logs tonight)
    Is there any way in hell to see the t and b settings in the ecu with vagcom?
    - Scott
    Das Build Thread
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: SPS3
    Quote Originally Posted by Molotov View Post
    Mode 2 is only needed to use performance mode if you had previously switched to valet or stock mode.
    You can log block 115 to see the requested vs actual boost. Log block 003 to check the timing and 020 for correction factors.
    Feb 24 2007
    Burlington, Vermont
    Re: SPS3
    yup thanks, gotta wait until tonight for logs. I'm hoping to be able to get blocks 003, 020, 115, 031, 032(?), and what the hell why not 001 again. VERMONT SUCKS FOR LOGGING DATA
    //edit.. i tried mode 2, because theoretically ecode could have set sps to inactive?
    - Scott
    Das Build Thread
    Senior Member Two Rings starfriend's Avatar
    Oct 17 2007
    A4 GTRS
    Norway
    Re: SPS3
    hi molotov, did you ever figure this out? :)
    A4/B6-2001 [Eurospec]
    430cc Genesis //GTRS// REVO //ATP// CUSTOM 3" EXHAUST w/ Magnaflow Mufflers //BSR OPTIFLOW INTAKE// FORGE SPLIT-R //Neuspeed Xtreme TIP// Racetec FMIC //Hitachi E//
    Feb 24 2007
    Burlington, Vermont
    Re: SPS3
    yeah, I saw your thread where you were having problems. You have the sps select plus though right? With the sps 3 I just had to key to accessories for 10 seconds, then insert for several beeps, then take the key out for 10 seconds before starting the car. Don't have a clue if there's a difference between the sps's
    - Scott
    Das Build Thread
    Oct 17 2007
    A4 GTRS
    Norway
    Re: SPS3
    got the plus yeah, and i have a thread going on :) oh.. well i do those steps aswell.. damnit i cannot for the life of me figure out wtf is going on ;)
