Results 1 to 15 of 15
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    forge red spring.. haven't received a definite answer
    So yes I know this spring will be strong enough to hold my dv closed when I'm only boosting 21 psi, but can it hurt my turbo? I think my vacuum reading is -25 which isn't enough to open the dv with the 30+ spring?
    Don't truly understand it. Thanks for any info, I'm off to go make sure every hose is tighter than a virgin (only holding 17psi on b7)
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Feb 17 2005
    Sarasota, FL
    Re: forge red spring.. haven't received a definite answer
    Softest to Stiffest
    Green
    Yellow
    Blue
    Red (30psi IIRC)
    And yes, too stiff of a spring will keep the DV from opening, you need yellow, at most yellow and a shim for 21psi, unless of course thats 21psi out a GT42R lol
    Feb 24 2007
    Burlington, Vermont
    haha no worries I'm probably never going to go bigger than gtrs. Could the spring be stopping me from making my 21 psi? I've put the stock one in, and I think I peaked 20psi with it, but not absolutely sure. That thing is going to be destroyed before I can find out.
    - Scott
    Das Build Thread
    Feb 17 2005
    Sarasota, FL
    21psi on a GTRS should need yellow and one spacer
    Registered User Two Rings
    Sep 04 2007
    MK5 GTI
    Orlando FL
    Quote Originally Posted by A4ringedONE8T View Post
    I concur.
    Yellow spring by itself, or with one shim.
    Feb 24 2007
    Burlington, Vermont
    yup I picked up the tuning kit.. have been running yellow and 1 shim on 22 psi
    - Scott
    Das Build Thread
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    I'm running a yellow spring (no shims) on APR Stage 1+ (I'm guessing that's fine according to the guide?), but my question is who here is using the RED spring?
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Sep 04 2007
    MK5 GTI
    Orlando FL
    I seriously doubt that many people, if anyone at all on this forum, is using the red spring. Which is why we typically don't include them with the 007P valves.
    As the specs. list, we typically find that it is only suitable for higher boost levels, usually exceeding 30 PSI or more. Of all of the different applications that we make application specific valves for, over 50 at this point, rarely ever does any one of them use the red spring.
    On very few occasions, I have seen people with Mitsubishi Evos use them, but only when they're using a larger than stock turbo and running really high boost as well as using race gas and running meth injection. It's typically just too stiff of a spring for the boost levels seen on most applications and would actually prevent the valve from opening properly in most cases.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I run one yellow and that is it with my 004...always performs flawlessly. It is a good idea to keep them clean and lubricated with Mobil 1 synthetic grease.
    I clean mine with every oil change.
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    is it bad if i'm running stage 1 with the yellow spring no shim? thats what the APR guy told me to run. Its a forge stealth valve BTW
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Aug 26 2005
    Quote Originally Posted by 05A$SE View Post
    It's not bad if that works for your setup. In general , the lightest spring possible that keeps the DV closed during boost, provides for best DV response. The difference between spring rate and spring preload must be considered during DV setup, increased preload effects overall response, but differently compared to a stiffer spring.
    Sep 17 2008
    2001 Audi S4
    Mary Land
    Straight from the forge site.
    If you are finding that the valve is dumping more than required or you are loosing boost pressure it is normally an indication that a stronger spring is required. Conversely if the valve is failing to dump it may be necessary to install a weaker spring. If during this tuning of your valve you are faced for example with the red spring being to strong and the blue spring to weak, you can add the spacers to the blue spring to increase the tension by small increments, thus achieving a setting between the red and blue springs.
    Valve Spring color coding
    Green - 5-15 PSI
    Yellow - 15-23 PSI
    Blue - 23-30 PSI
    Red - 30 + PSI
    The above figures are estimates only and should only be considered as a guideline
    Please note - fitting a stronger spring into a valve will not increase boost pressure unless existing pressure is being lost. Failure to allow the valve to operate by installing a spring which is to strong may cause damage to the turbocharger.
    Please note - the red coded springs should not be installed in the DVR or DV007 diaphragm valves
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Its generally advised to use a yellow spring for 1+ correct? Because i've heard you hold 14-15psi but spike around 19-21psi.
    -Matt
    FCDT Member #1
    Sep 17 2008
    2001 Audi S4
    Mary Land
    Quote Originally Posted by mdzaudi View Post
    I use yellow on stg 2+, but I would use yellow at 1+ as well.
    Jun 30 2007
    Raleigh, NC
    fwiw - if you're using the red spring you probably need something bigger than the ports on a forge will allow, and it might also be time to start thinking about not recirculating that air... (aka - going MAFless, putting a BOV closer to the throttle body, etc)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
