Results 1 to 6 of 6
Thread: window problem
    May 15 2007
    Chicago
    window problem
    my drivers side window won't roll up. anyone had this problem. any DIY knowledge so i can fix this. thanks.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: window problem
    search for "window regulator" - someone did a DIY not too long ago. Looked too involved for my skills though.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Re: window problem
    yeah i just roll mine up manually (one hand on the outside, one hand on the inside.. squeeze and lift) Haven't gotten around to purchasing a regulator and installing it. DIY doesn't look too hard as long as you're careful
    here is the DIY
    http://audizine.com/forum/showthread...ndow+regulator
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    May 15 2007
    Chicago
    Re: window problem
    rolling up the window manually won't damage anything inside? thanks for the input.
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    Re: window problem
    ^^No^^ also a window regulator is like $145.00 for the part.
    05 Triple Black 1.8T Quattro Tip.
    Feb 24 2007
    Burlington, Vermont
    Re: window problem
    i think its about 110 on genuineaudiparts^
    - Scott
    Das Build Thread
