Originally Posted by
Molotov
forge 007 from 20v turbo, don't know what spring is in it right now (car is too hot to bother taking it out.. waiting for cool down)
Anyway I want to run anywhere from 21-23 psi, if I do have the yellow spring in there (I hope, don't want to buy the kit) then how many washers should I be using?
(car currently holds 17psi.. trying to trouble shoot possible leakage without pressure testing yet)
And if my dv actually had the green spring, I wouldn't be able to put enough washers in would I?
Try reinstalling the DV in the "reversed from OE" orientation direction, that is with the large bottom connection to the turbo compressor discharge > intercooler inlet pipe, and the DV side port connected to the turbo compressor inlet hose. The Dv will hold more boost without leaking in the reversed from OE orientation direction, by using boost pressure to help keep the DV closed, while allowing for the lightest spring to be used. In general, the lightest spring rate possilbe while providing for a tight seal under boost, is prefered for best DV response. Adding sping preload, or using a stiffer spring will delay the opening response of the DV when lifting the throttle during gear shifts.
