Results 1 to 12 of 12
Thread: aftermkt turbo
    Registered Member Two Rings
    Aug 08 2008
    cupertino, CA
    aftermkt turbo
    so most probably my turbo is gone and i am looking for the cheapest way to replace/rebuild it. my mechanic found some rebuilt ones which cost around 500 bucks, and i found some on ebay motors which are at half of the price, and brand new like this one
    http://cgi.ebay.com/ebaymotors/AUDI-...mZ220269747343
    again, i am totally new to cars and i just wonder if the quality of aftermarket turbos are reliable....and why is it so much cheaper than a rebuilt one?
    thanks and i appreciate every input!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: aftermkt turbo
    No, it wont fit. Buy a real one!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Aug 08 2008
    cupertino, CA
    Re: aftermkt turbo
    Quote Originally Posted by biketsai View Post
    it wont fit? why? what's the problem with these products?
    Dec 08 2006
    Cincinnati
    Re: aftermkt turbo
    It will probably fit, but that isn't really the issue. This turbo is not made by borg-warner (company that makes k03 (and k04)), rather it is some random Asia based company which sells knock-offs. A number of people have had issues with their turbo dying after several thousand miles. Do a search on here and Audiworld.com and you will see what I am saying.
    Find a real one, or even better, have yours rebuilt by gpopshop. The only issue is it would require some downtime... Unless you could work out a core exchange of some sort where you sent yours back to them right after receiving (and installing) theirs.
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    Re: aftermkt turbo
    Dont buy the Asian shit, it will be dead in 5K miles...
    And with a chip i'm hoping you will make 5K on it..
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
    Aug 09 2007
    Mount Airy, MD
    Re: aftermkt turbo
    and the ad has contradicting/wrong info. it looks like they just copied and pasted,
    K03 TURBO CHARGER SPEC:
    4" INLET OLD SIDE
    2.5" V BAND HOT SIDE
    WET FLOAT BEARING
    DIVIDED T3 SIZE FLANGE
    OIL COOLING TURBO CHARGER
    600 HORSE POWER CAPABLE
    heck i dont think 3 ko3s could make 600hp
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Dec 05 2007
    Re: aftermkt turbo
    You could source a used one for maybe $150. It is just a little harder trying to source a k03s. Here, let me help you out.
    Link 1
    Link 2
    Or you could call A&P. They usually have great prices.
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Re: aftermkt turbo
    yeah i didnt know ko3s had t3 flange aswell, lol
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: aftermkt turbo
    that shit will split in half
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Re: aftermkt turbo
    My buddy owns a mechanics shop had a v-dub with a blown turbo, and a tight wad customer. Put one of those e-bay knock offs in and it fit fine. He told the customer NO WARRENTY!!! though. lolz
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: aftermkt turbo
    Great for Audi A4 96-03, VW passat 98-03 OE replacement.
    1.5" Inlet, 2" compressor wheel to intercooler.
    2.5" Outlet 3 Bolt standard, fit VW, Audi 1.8T Downpipe.
    Journal Bearing.
    Internal Wastegate at 12 Psi.
    200 HP Capable.
    4" INLET OLD SIDE
    COMPRESSOR WHEEL SPEC:
    WHEEL: 0.36 A/R
    TURBINE WHEEL SPEC:
    WHEEL: 0.87 A/R
    That has got to be the dumbest turbo description ever. I don't even want to start w/ how wrong that is.
    Quote Originally Posted by bob12312357 View Post
    That's when you explain to the customer that you don't do b/s work.
    I've installed customer supplied parts numerous times. When they come back with a bigger problem in 2 months, we have to charge them again b/c they didn't listen, and we had to do the work twice.
    We stopped installing customer supplied parts at that shop. The shop I work at now will, but our customer's supply good parts, like ones from 034 and techtonics.
    Aug 21 2008
    Minneapolis
    Re: aftermkt turbo
    I would NEVER EVER buy a turb off ebay... I made that mistake buying one for my Civic 2Dr and it blew the next day... If you do but it make sure that it has a return police and everything... You may be better off buying from one of those ebay stores if you do go through with it....
