Results 1 to 4 of 4
Thread: COOLANT
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    COOLANT
    so I finally got to drive my car after the gtrs install, well not shortly after getting on an interstate does my car start to overheat and flash coolant signs at me.
    So I pull over asap, pop the hood, get my flashlight and start looking.
    1. Coolant reservoir is in it's happy place between min and max.
    2. None of the coolant appears to be leaking out of the block or turbo.
    3. It was making gurgling sounds near the coolant line in front of the engine block.
    And yes, I took the ecu out, and cranked for 10 seconds at a time for ~20 times
    any ideas?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Dec 06 2007
    Re: COOLANT
    ^^either ur waterpump just gave out, or ur temp sendor or coolant flange took a dump. i believe the waterpump is the culprit, same happened to me.
    -Kirk
    BetaAlphaTau Member #58
    Feb 24 2007
    Burlington, Vermont
    Re: COOLANT
    almost immediately after going to bed i realized theres a lot of pressure from the fmic piping on the coolant line just before the radiator. Is it possible to pinch this line between the piping and bumper? It's really tight.
    Could explain why it overheats, then cools down and warnings go away, then come back?
    - Scott
    Das Build Thread
    Feb 24 2007
    Burlington, Vermont
    Re: COOLANT
    bump, is it really possible to pinch that bottom line so easily?
    - Scott
    Das Build Thread
