Results 1 to 17 of 17
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Unhappy possible boost/vacuum leak... chime in
    Hey all,
    did a boost leak test yesterday because i was concerned about a vacuum leak. I found a small leak and tightened a clamp but i have a few questions. this is the first time i have done this test.
    1. I hear a small hiss coming from the throttle body area. to me it sounds like boost leaking by the throttle body. It is not leaking into the atmosphere that i can tell. Is this normal?
    2. I removed the oil fill cap to prevent hissing from the crankase, and when i return it into place and plug the PCV valve with my thumb, after pressure builds a little i can start to hear a little hiss down by the front of the intake mani on the drivers side. this one concerns me a little. BTW, just did my afterrun pump and intake gaskets 3 weeks ago. But the boost and vacuum do not read any differently than they did before.
    when i start the car cold, vacuum is at around 18 hg or so. if i raise the rpm to around 1000, still in park, i get 20 hg. coasting in gear i get 21 hg. after car is hot at idle in park i get around 16-17 hg.
    What do you think? boost seems normal.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: possible boost/vacuum leak... chime in
    You need to pressure test again. Fill a spray bottle with soaping water and start spraying parts when you pressure test. Where you see bubbles is where you have a problem.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    ^2nd.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jun 14 2007
    2000 S4
    Connecticut
    3rd, usually your vacuum at startup is generally lower ( like you said you have 18 when cold then when warm its 16-17 ) it should be the other way around, but 16-17 is kindaaa low. Things like your air intake setup (stock airbox or not) can affect but as the others said check for leaks. even the Samco TBB can tear, and since you're a 2000 like me, check the F hose. the F hose being torn for so long in my car led to the K03s poppin!
    Dec 02 2007
    michigan
    good stuff guys i'll try all of that. I was under the impression that the pressure tester is only good for testing the system up until the throttle body. I am hearing this slight hiss near the intake manifold. any ideas on this one and how to test? I will definately use the soapy water test. I was hoping somenone on here would have some experience with post throttle body leaks and how to track them down. prior to the throttle body, all is well. thank you for the replys and keep the ideas coming!
    Jun 14 2007
    2000 S4
    Connecticut
    ahh hiss near the intake mani?? are your injectors seated correctly?? have they ever been touched, if so they could not be seated all the way in, as if you should remove Y pipe and push down on them if you can OR your injector O rings, if they are really old and have never been touched can be leaking.... somehow you have to spray some water down there. i would take off Y pipe, spray each injector, attach Y pipe and look for bubbles....
    Dec 02 2007
    michigan
    good points, i'll add them to the list. thanks. anything else anyone can think of? I would like to get the best list of items to check together so i can be thorough the next time i raise the hood.
    Jun 14 2007
    2000 S4
    Connecticut
    i would REALLY think first start small at the F hose... since you're 00 like i am... one time coming home from the city i wasnt boosting quite as high as i used to (at the time i had GIAC and 19 was normal) so for a few days i thought i had a bad tank of gas possibly. i even made a youtube video LOL titled "GIAC X BAD GAS" after pressure testing, which many people seem eeh i dont NEED to, i found a leak at a few clamps. so i fix the leak and i still had air coming out... sure enough it was that dam little F hose, and during the install the clamp fell off, F hose came loose, and i sucked something in just eating the turbo to bits. so go out there and fix it! haha
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    A bolt on my drivers side turbo was backing out causing a major leak. Not sure how common that is?
    Good luck finding your problem!
    Dec 06 2012
    B6 audi a4 avant
    Sacramento California
    Some aviation mechanics recommended to spray brake cleaner and listen to rpm rise, you found your leak.
    Oct 03 2012
    Rochester, NY
    Quote Originally Posted by nvrfollow View Post
    I have a boost leak coming from my drivers side turbo, and this may be my issue. It's been a bit cold the past few days to be in the garage so I haven't gotten a chance to get back under the car.
    Jul 03 2015
    socal
    So what all did u have to do to get the passenger wastegate line fixed?
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Quote Originally Posted by s4Bman View Post
    Replace it.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    May 16 2008
    WA
    I don't see anyone in this 2 year old thread mention a wastegate
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by getslideways View Post
    Eight years old. This thread is eight, years, old.
    May 16 2008
    WA
    Quote Originally Posted by Zba View Post
    holy moley, i just read the '13 date on the last few posts and thought that was bad, didn't realize the thread had been borrowed from The Smithsonian!
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    Hey, at least he searched haha.
