    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    new clutch issues...
    i have my new clutch and 12 lb flywheel for my 03 1.8tq.. next weekend is when it is getting put in. any tips or tricks or hints to make it go smoother?? anything i should look for?? anything i could possibly get stuck on?? i kno that just about everyone here has done their own clutch so you have more experience doing it than i do.. i will have the car up on a lift. tia!!
    festerfm
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Re: new clutch issues...
    a4mods.com, check the clutch install DIY. read all of it before you do anything
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jan 24 2007
    make sure you line up the engine & trans correctly. Don't just slam it in because it will do alot of damage take your time...
    Feb 07 2008
    just the a4
    northeast pa
    ok thanx. i did a neon trans bout 6 yrs ago and it didnt come w/ an allignment tool and we just lightly snugged the pressure plate bolts and ligned it up with the pilot using a piece of pvc pipe.. the kit i just got didnt come w/ an allignment tool so i imagine i will be doing it the same way. also where can i get new flywheel bolts???
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I align discs without a tool all the time. Most discs and PP's are the same diameter or close to it. Lightly snug the bolts and adjust the disc to be equal all the way around, then tighten it up.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
