Results 1 to 11 of 11
    Dec 29 2004
    Raleigh, NC
    Those running Miro 279 wheels (LM reps) would 38 et work on the S4...
    Need a quick response as I will meet with the guy in about an hour who has the set. TIA. Oh and the S4 is in the shop so I can't test fit.
    2001 AWE Stage 3 S4
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Re: Those running Miro 279 wheels (LM reps) would 38 et work on the S4...
    i think you need to run some 5mm spacers to clear the hp2 calipers. giving you a 33 offset
    Dec 29 2004
    Raleigh, NC
    I scooped up the wheels today. I was thinking the same. Thanks Adam. Can't wait to throw them on.
    2001 AWE Stage 3 S4
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    negative... i bought some today myself... looks to me like we need an 8 - 10mm spacer
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Dec 29 2004
    Raleigh, NC
    Let me know what kind of spacer you end up using. Are the ones you bought a 38 offset? Are they the Alt Tangents or the Miros?
    2001 AWE Stage 3 S4
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Need an 8mm spacer. Not too bad.
    --Adam
    Have questions? E-mail me.
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    I run them, and I have 8mm spacers, and I had you grind down the caliper a little bit too. I think 10mm if I'm not mistaken, but the wheels I ordered were all machined all wrong! They came with mercedes hub size and back spacing. Annoying.
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    post up some pics once they are on
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Dec 29 2004
    Raleigh, NC
    I definitely will. I'm working on going Stage III. Once that is all settled, the wheels are coming on (within the next week or so). I picked them up used for a great deal locally. I just cleaned them up, and they perfect. No nicks or curbage so I'm happy. Should I go 8 or 10mm with the spacers?
    2001 AWE Stage 3 S4
    May 04 2005
    Connecticut
    im goin with 10 just to be safe
    2000 Audi A8
    Active Member Two Rings beefcake's Avatar
    Aug 15 2010
    2008 post bumped. Anyone have Miro Type 279 wheels with a 35mm offset on a B5 S4 with new front brake pads. Is 10mm spaces enough and any rubbing on a lowered car? I am thinking about putting some on my B5 S4 with stock calipers and new pads.
