Results 1 to 9 of 9
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Noob ?...Stock Amp Location?
    i have the bose system...where is everything located?
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Established Member Two Rings tarzjdm's Avatar
    Jul 15 2007
    B6 1.8t FWd
    san dayGo
    Re: Noob ?...Stock Amp Location?
    The stock sub is located on the rear deck lid.
    The stock amp is on the side panel in the trunk, its behind the passenger side vent
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by tarzjdm View Post
    whats the best way to access it?
    2003 A4 1.8T
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    ya gotta pull the carpet side out
    which means false floor,
    remove some of the weather striping,
    to take out the plastic piece along the bumper,
    floor anchors,
    and the back rest of the passenger seat (unless your carpet is very flexible),
    then some pulling and swearing and it out so you can star the actual project.
    think thats all
    Please Drive Right
    Aug 14 2008
    Portugal
    Don't you have some photos? I have the same question. I search everything to know where the exact place for the amp
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Here's a quick pic of the stock bose amp in the rear passenger side wheel well:
    ...pretty much what Pothole said.
    I have the rear seat bottom removed as well, but no need to do that.
    I'd def take out the rear seat back to get the carpet/trunk side out. There's one torx screw holding the seat backs in place (where they both come together/hinge).
    Aug 14 2008
    Portugal
    Perfect! By the way, to A3 8L does anyone knows if it's in the same place?
    Senior Member Two Rings dreVanHalen's Avatar
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    is it in the same spot on a 2000 a4? i need help with this asap. I want to just bypass the amp instead of running all new wire.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    I actually did this a couple weeks ago but didn't have to remove the seat back. All I did was put both seat backs down and then pop the top of the rear deck lid upwards. The carpeting closer to the front of the car slides out from its position and then you just work your way around the top towards the back of the car pulling it down. IIRC there is one pop clip(not sure what to call it) that pops right out, towards the top of the carpeting and pretty much in between the front and back of the trunk. You may want to remove the cargo hitch(2 torx screws) as well. Otherwise there should be more than enough space to slide your arm in to get access to the 3 screws holding it in.
    DG '02 A4 1.8TQM
    My Build Thread
