Results 1 to 7 of 7
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    DIY Speaker grill replacement...
    I know this sounds real easy but it isn't... with that being said this should make it easy and save you some money in the process.
    My passenger side rear speaker cover was cracked and was bothering me every time I saw it; so I went to the dealer and bought a new one not realizing that it isn't just screwed in to the door card.. So to make a long story short, I searched inspected the inside to find that the cover is plastic welded into the door card and would take a little more time.
    So here it is:
    Tools:
    Drill
    Drill index
    Philips Screw Driver
    Butter Knife
    Stove
    painters tape
    Parts:
    New speaker grill
    Quick clips that help secure the door card
    1. Start by removing the door card. This is done by removing the belt line trim. Pull from the front of the door and it will pop away, note hooked end for reinstall.
    2. Remove three screws behind belt line trim and one screw under armrest in recessed hole. You should look like this.
    3. Gently pull door card bottom out, you'll hear snapping and may brake one of the quick clips (hence why you may want a few) This what they look like.
    Then pull the sides off and pull the card up out of the door. It is a little tricky but you'll get it. There are also two small whit quick clips on each end of the top of the door that you have to pull hard to get off.
    4. Next remove all connection to door and door car, door handle cable, speaker plug, and window regulator plug.
    The orange one and there is a clip on the back that you depress and pull down.
    5. Sweet, now you have the door card off and the work begins..
    6. I used a drill to break the plastic welds on the back of the speaker grill. I started with a small 1/8" and when used a larger 3/8" drill bit to break the remaining plastic away. Take your time so you don't break the plastic tabs on the door card.
    No screws..
    Time to drill..
    Pop out the old grill...
    Wow that thing was hammered..
    7. Now you can install the nice new grill. I used the painters tape to secure the grill in place nice and flush and then supported the back for the next step with a phone book may be thick enough if you live in a city but may need another book.
    Now you get to do the DIY plastic weld. I used a butter knife and the stove. If you don't have a gas stove this may be tough but I'm sure a soldering iron or torch could assist in this process.
    Press firmly until exposed plastic is melted flush with tab and pull away as to not get the knife stuck to the door. It should look like this when you are done.
    8. New grill is in so all that is left is to reinstall the door card in reverse. The screw on the bottom of the handle is a pain, I would recommend a magnetic screw driver and also to make not of how it goes in while the card is off.
    9. Sit back and admire a job well done and have a frosty adult beverage if your of age..
    Comments or suggestions welcome..
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Re: DIY Speaker grill replacement...
    Well that helps alot... I made the mistake of prying mine off thinking it was just some pop off tabs, to quickly find out it wasnt going in. I got a new cover and I've had it in its spot but it keeps falling out. I thought I had to get a special tool to expand the tabs. on the DIY.
    DG '02 A4 1.8TQM
    My Build Thread
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Yeah that is why mine was so hammered, my brother thought he would help me out and replace it for me while I was away to discover it just broke more as he pulled on it... I hope it works out for you and remember to take your time with removing and reinstalling the door card so you don't break to many of the quick clips..
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Thanks, Pete. I need to do the same thing. My girl broke my passenger side one a while back.
    Jun 13 2008
    Bay Area
    this is very helpful.... my wife has been bothered by our speaker grill being cracked from day 1, lol... will have to pick up new grills next week and switch em out... thanks for the diy!!!
    btw... how much did a new grill cost at the dealer?
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    very helpful indeed
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I think it was around $25 and the clips were $2..
