Results 1 to 27 of 27
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Best ebay FMIC and Piping?
    I know alot of you guys have ebay FMIC's and piping so i was wondering which cores and piping you guys are all going with(link or ebay seller id)? i have an s4 bumper so mabe i can go a little bigger than most of you guys with the stock bumper. thanks alot guys
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Re: Best ebay FMIC and Piping?
    or mabe what size core fits behind an s4 bumper nicely or with moderate cutting? my bumper is rs4 modded if that makes any difference.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    s4 bumper can fit a pretty big core, has the most room out of all the bumpers. there is a thread about this, or i should say about 100 threads. CXracing is decent as far as ebay. That is who I went with.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Here's a thread of when I installed my FMIC on my A4 w/ the stock bumper. Scroll down and you'll see the dimensions of the it and all the pipes that were included in the kit.
    http://www.audizine.com/forum/showthread.php?t=157337
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Jun 01 2008
    Apopka, FL
    I bought a goodspeed intercooler kit on ebay it was fairly good quality and came with a 400hp core and 2" piping that uses the stock throttle body hose but it does have a flange for the dv not bad considering the cheap price.
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    do any of the ebay kits come with the fittings in the piping for like the map sensor i believe? or anything like that, or do you have to cut and make your own fittings?
    what is the recomended inlet size for bt setups? 2.5?
    2004 Subaru Impreza WRX
    Aspen White
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Man ebay FMIC..... lame ass shit
    Aug 09 2007
    Mount Airy, MD
    Quote Originally Posted by le91688 View Post
    do you have one? cause i dont think anyone who has one has any complaints. its a pretty good deal if you ask me. as far as the map sensors for the dbw cars, theres a little flange you can get and weld on.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Feb 28 2007
    04 a4 USP ; ATS
    ^^ why is it lame?? when it works...
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Don't be jealous, Mr. 2.8.
    Lots 'o Goodies
    Sep 20 2004
    2001 a4 quattro
    Sactown
    ur the lame ass mr just joined and have a 2.slow
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    easy guys, this isn't Vortex or your local rice burner shit talking forum.
    If it works and you're not picky, roll with it. I picked up my core from CXRacing, and I have not ran the pipes yet.
    As far as a MAP bung I don't recall anybody supplying one other than the bigger companies. I know 034 supplies them with their BT silicone piping kit, as I have that. Unfortunately it doesn't work well with the K03 as the hot side doesn't fit right.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    You should match the FMIC to the turbo not to your bumper and sorry but bigger doesn't mean better.
    BONFIRE074 - Depends on the size of the turbo. You should try to use the same size pipe as that of the turbo outlet. So if the turbo has a 2" outlet you want a 2" pipe or can go up to 2.25" for this while using the same size cold side pipe or .25" larger. If you go to large you can decrease velocity which does effect boost lag and threshold.
    Senior Member Three Rings kelticslob's Avatar
    Dec 08 2005
    Ontario
    Ideally, but will your car be slower with an improperly sized core, or slower when you can't put the bumper back on because nothing fits?
    2000 1.8TQM: APR 93 Chip; 710N; Clear Corners; H&R sport/Bilsteins; Piano black trim; modified S4 front; 18" B7 RS4 rims/ Bridgestone Potenza S-03 Pole Positions
    2001 1.8TQS - stock
    Jul 07 2004
    socal
    Quote Originally Posted by kelticslob View Post
    Well even a small FMIC is better then the stock SMIC. The bumper off isn't exactly going to make the car slower, there will just be more damage when you hit something at any speed and your chance for a ticket goes up.
    Feb 13 2008
    look for 42 draft design, I believe that is the correct name. They will have a map sensor adaptor that you can use to attach to 2 or 2.25in piping
    Aug 13 2007
    Aspen White
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Quote Originally Posted by a4rings View Post
    Best?
    NON-eBay. Period: they have little IF ANY engineering expertise behind them.
    42DD
    ECS
    Forge
    Do the right thing.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Quote Originally Posted by InTTruder View Post
    Best?
    42DD
    ECS
    Forge
    Do the right thing.
    you are an idiot do you run an ebay fmic? they have been proven to work perfectly fine from stock up to GT series turbos. for the price they can not be beaten plain and simple. I run an ebay fmic on my GT2871r and my intake temps are awesome. just because its from ebay doesnt means its garbage
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Hey, I bought an Audi off of ebay... It's garbage...
    ΜΟΛΩΝ ΛΑΒΕ
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    ebay fmic ftw. Your just an idiot if you cant make your own and get on AZ and say they are pieces of shit.
    edit: truth, im on a budget! haha
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Best?
    42DD
    ECS
    Forge
    Do the right thing.
    Last I checked ECS doesn't make shit, they just sell it. Especially FMIC setups. They sell APR and Forge stuff, but nothing branded "ECS Tuning".
    I'm not going to call you, or anyone, an idiot on this topic. It's all in your preference. Ebay kits, intercoolers and other b/s works great for some. Especially those that don't want to spend $900-1100 on a FMIC setup.
    Some of us don't like spending more than we make in a paycheck at a time.
    Jul 07 2004
    socal
    Quote Originally Posted by Ewok_Fetus View Post
    Wow, I didn't know your Audi was made in China.
    Quote Originally Posted by djwimbo View Post
    The ebay companies dont make their FMIC kits either, they have some 5-10 year old kids making it in China for 5 cents a day.
    Do you buy crappy looking wheels for your car too just because they work? Because every Ebay fmic I have seen looks like it doesn't belong on the car at all. I guess some people would rather pay for something that is designed for the A4 and looks good enough to not make people point at it because it stands out like a sore thumb.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'd love to buy a quality core and properly designed piping. The problem is located (or lack there of) in my bank account.
    For what I want it'll work for now. On top of that, I'm working on something that I haven't seen done yet in the B5 world too. Which means scrapping some of my current plans and parts.
    I'm not trying to piss in on your parade, I don't want to make any enemies. When I have the cash to do stuff right, 034 or yourself(mike) will probably be on the receiving end of my cash.
    Jul 07 2004
    socal
    Oh I understand there are people that cant afford quality aftermarket parts and thats when Ebay usually comes into play. But as most people know, you get what you pay for.
    At this point I didn't think there could be anything that hasn't been done on the B5, well unless your thinking of doing a jet engine in the car.
    Veteran Member Four Rings Yevmeister's Avatar
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    I have Avant would be a perfect frame, now just waiting for sponsors
    Yev
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by Yevmeister View Post
    Yev
    Hey if I was still in the Air Force, I would have stolen a jet engine from an AWACS for ya! 21k lbs of thrust sounds like a lot of fun!! Couldn't move the AWACS worth a shit but I am sure it could move your Avant! I mean, hey, your tax dollars paid for it right?
    (For anyone in OSI, FBI, CIA or any other military/federal investigating office, I was just kidding...)
    ΜΟΛΩΝ ΛΑΒΕ
