Results 1 to 3 of 3
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    FMIC Install Question - Stock Hose?
    alright, i pulled the bumper and started to fit some things last week. I have a generic kit from ebay and am trying to figure out the best way to route from the turbo to the the FMIC.
    Should i reuse the original hose from the turbo to the bar that cross the front of the car? If i do that i will need to find a "whatever the stock size is" to a 2.5" then to the FMIC.
    if i replace the hose with the tubing from the kit then i'll need to get a T with a 1" coming off the side to connect the DV to.
    what did you guys do?
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Re: FMIC Install Question - Stock Hose?
    i would get the T if I were you
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    The kits I have seen all do the There is usually a elbow or connector (silicone) of some sort from the turbo to a pipe diamater of your choice right out of the turbo, on that pipe about mid way down on its way to the next connection they weld in a 1" tip to hook the dv hose to. After that it is the usual elbows and clamps and pipes until the intercooler. Once you cross the intercooler and get to the driver's side you will now need to make the tubing go towards the intake (trottle body), before this however you will need to add a spot in the piping going to the intake for the sensor that is in your stock mintercooler now.
    I recomend you use T bolt clamps on all the connections and make sure all the welds are air tight, any air leaks will affect your boos and the performance of the car and will be an all around PITA.
    Good luck, hope it helps.
