Results 1 to 25 of 25
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    APR1+ with stock SMIC and meth?
    Would i have any problems running 1+ with a stock smic and water/meth?
    Looking at getting snow performances stage 2.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: APR1+ with stock SMIC and meth?
    Nope.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 25 2007
    The water/meth wont stop the smic from heat soaking tho right?
    Is it possible to add another nozzle just before it to help cool it down?
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Mar 21 2006
    Lakeland, FL.
    I wouldn't, the water will just pool up inside of it. You could put one in frt. of the IC.
    I'm back bitches!
    Nov 25 2007
    How about APR's 1+ 100oct file?
    Just for reference ill be running 94oct
    Some Go, No show
    Wish List
    Nov 25 2007
    Any one?
    Some Go, No show
    Wish List
    Mar 21 2006
    Lakeland, FL.
    You should be able to run the 100 oct. file on a good WW fluid. Just run logs to make sure you're not pulling to many CF's.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    APR 100oct file won't happen, especially with the stock SMIC. You should be able to add around 3 degrees of timing though with Lemmi to the 93 program. As Chris said, NEVER put a meth nozzle BEFORE the IC core, it will just pool up inside
    Mar 21 2006
    Lakeland, FL.
    You would know better then me, as you ran APR before.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    APR K04 + FMIC + TP + 275cc W/M single nozzle (on Snow stage 2 - MAP controller) I ran 5 degrees of added timing with Lemmiwinks. 100 octane file adds approx 7 degrees of timing at peak over the 93 file. FWIW and IMO, 5 degree graph shift > 7 degree peak. CF's on the 100 file on 93/meth were 8-10 (just under audible detonation). CF's on 93 + 5 degrees were 4-5
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by A4ringedONE8T View Post
    Awesome information. That's about what I have planned for mine. Injectors should be here next week, I'm shopping around for a K04, have a used Neuspeed FMIC downstairs awaiting installation, and a Devils Own dual nozzle meth kit in a box in the living room. Test pipe will likely be done when I do the K04, but I'll install the intercooler and meth kit after I get the injectors and 1+ flash (APR).
    Edit: How did you like the power on that setup? Anything you would do differently? Did you ever dyno it?
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by nihil View Post
    Glad I could help. I never ran the meth with 1+ but I would imagine it is very similar to the K04 file regarding timing and CF's. When adding timing with Lemmi, please add timing 1 degree at a time and log after each change. Make sure you also do it on a hot day (the hottest you get) or don't max the settings out. If you set your CF's to a max (5-6) on a 80 degree day, on a 95 degree day your CF's will be damn close to if not at the detonation point. The key with meth and adding timing with Lemmi is to log, log, log. I can't stress it enough! Also keep in mind Lemmi tweaks do adapt out overtime and particularly if your voltage drops (from the car sitting for an extended period of time) so be sure to check your Lemmi settings about once a month to be sure they are still present, never hurts to log once a month as well to make sure everything is still in check and CF's/timing are as you left them.
    For those that don't know and new to the meth/lemmi tweaks, I would aim for daily 5-6 CF's MAX! This allows a little bit of room for the car to run differently day to day and not cause any problems. CF's > 10 = detonation with 11-12's usually being audible detonation
    Feb 17 2005
    Sarasota, FL
    It was great at the time, yet still never enough
    I definitely recommend an ATP/034 manifold with a K04. It will remove the annoying torque spike the K04 has and makes the power/tq much more usable. It also lengthens the powerband by about 500rpm.
    APR K04, 93/meth, 275cc nozzle, FMIC, TP, Exhaust, Carbonio V2, APR TIP, 90 degrees on the dyno 210whp/267wtq
    Same setup, same temps, just adding the ATP mani, 218whp/274wtq and about 10-15% more area under the curve
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    While on the subject of logging, is there any good resource on logging? Maybe a guide that makes it simple for those who wouldn't really have a great idea what to log/what to look for?
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Nov 25 2007
    Thanks for all the good info.
    Im just starting to learn about the a4. Just lookin for a reliable daily driver for school. My previous car was a DSM that i had built up from stock. Best run was 12.2. It got stolen and stripped... Insurance company wrote it off.
    Mod plans: (in order, suggestions welcome)
    -VAG-COM
    -Boost gauge
    -DV
    -Test pipe
    -Intake (for sound purposes. I know....)
    -Snow Performance Stage 2
    -Injectors (where can i find a good deal on a new set?)
    -APR 1+/93 (For refrence i run no less the 94oct)
    What else would i need? Tuning?
    Im not lookin to go to crazy just a little extra pep
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    pm manguyen for the injectors, he's the cheapest non used injector resource
    "-APR 1+/93 (For refrence i run no less the 94oct)
    What else would i need? Tuning?"
    apr 1+/93 is the tuning....
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Nov 25 2007
    Quote Originally Posted by Molotov View Post
    Then why are we talking about adding/subtracting timing with Lemmiwinks...?
    Sorry if this is a noob Q.
    Would VAGCOM be a good idea to get?
    Feb 24 2007
    Burlington, Vermont
    lemmi is for tweaking the tune. wrong words right ideas. you'll want lemmiwinks
    - Scott
    Das Build Thread
    Feb 24 2007
    Burlington, Vermont
    if you like sounds, id skip the intake and get an exhaust.. way sexier and better for your car. Didn't see it on the mod list
    - Scott
    Das Build Thread
    Nov 25 2007
    Ok, thats what i figured. Im used to logging timing on a palm then adding/subtracting fuel using a air fuel controller.
    Id love to throw an exhaust on, but im trying to keep it on a budget.
    Aug 26 2005
    Water/methanol injection can easily allow advanced timing and increased boost using only the stock SMIC, beyond the timing and boost settings possible with a large FMIC without W/M injection.
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    Glad you're back.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Nov 25 2007
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Trev View Post
    You need either a vagcom cable or one of the USB/serial cheapies inorder to use Lemmiwinks
    Nov 25 2007
    When i order my 1+ chip from APR should i get the 93oct and 100oct files?
    Or should i just stick with the 93oct file and mess around with the timing and fuel through Lemmi?
