Results 1 to 16 of 16
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Intercooler ducting
    I now have the IPP large intercoolers, 59% larger than RS4, 68% larger than OEM S4/A6 2.7T. I removed the fog lights once I noticed how bad they block the intercoolers. I also cut some vents into the fender liner plastic since they are not vented. But I feel like some duct work & shrouds would help direct air at them. Am I supposed to have ducts in there stock and maybe just missing them? Doesn't look like it..
    Anybody know of any ducts or shrouds? Or maybe tried making some? Suggestions welcome..
    Thx
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Senior Member Two Rings rxphiler's Avatar
    Jan 22 2008
    05 Porsche Cayenne TT, 06 Ford Expedition King Ranch, 92 UrS4 sedan, 05 Volvo V50 Wagon
    Charleston, SC
    Re: Intercooler ducting
    I have thought about modding my fog grills like an intake and direct the air to the intercooler. But I havent got around to seriously looking at what it would take. But there is some stock plastic parts that feed air into the intercooler. When I bought my car it didnt have the fog light grills so I just left them open. Just my 2 cents
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by ENDEE666 View Post
    Thx
    The best you can do is modify the original ones and get any obstructions out of the way (fogs/grills/wiring). The other possbile solution is to modify an RS6 bumper to fit your V6 style fenders and gain the added IC opening size. I know it can be done but, it's definitely a fair amount of work to blend it in and still look correct.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    May 04 2007
    LI,NY
    Already did as much as possible to let air at them. I removed the fogs & brackets and I cut the slots open more. There was a section in the middle that was filled in behind the slots so I cut that open more. Looks the same from outside but now it flows. Going to post some pics.
    May 04 2007
    LI,NY
    Fog blocking intercooler-
    The part I cut away in the grille-
    No fog blocking intercooler-
    No fog 2-
    Established Member Two Rings Moonz_A6's Avatar
    Jun 22 2008
    Mesa, AZ
    Hi all.. I am new to the forum and new owner of a 2001
    Audi A6 2.7t 6-speed. I just came out of a 98 bmw 540i sport with a 6-speed. I've owned BMW's m whole life but it was time for something new. I have to say... I'm loving it!
    With that being said.. on to business. I too have the IPP intercoolers. I was wondering if there is enough space behind the intercoolers to mount 2 small puller cooling fans, well one fan per intercooler? I just bought the car and have not had any time to puller the car apart. So please forgive me for asking a question that may have already been addressed. I have 2 k04 turbos and a host of other goodies in the trunk to install as well. Any help would be greatly appreciated.
    Thanks
    Moon
    Feb 17 2004
    Sterling, VA
    Fans shouldn't be neccessary. I would buy a set of the RS6 fender liners and that will create plenty of air flow out of the back of the intercoolers. This will promote airflow in as well.
    Brett - Moderator
    Issue?: email me.
    May 04 2007
    LI,NY
    Anyone know where I can get the vented fender liners & if they will still fit a narrow body? Right now I just have some pretty clean holes cut in the back with some black mesh behind it..
    Feb 17 2004
    Sterling, VA
    The RS6 fender liners aren't made for the V6 body but, they are very simple to trim. You only have to trim the edges where it contacts the fender lip. The inner and bottom edges are going to fit the subframe contours.
    They should be $30-40ea.
    Brett - Moderator
    Issue?: email me.
    May 04 2007
    LI,NY
    Thats it?? Only 30-40 ea?? Where?
    Jun 04 2007
    Huntsville, AL
    x2
    Veteran Member Three Rings pohsib's Avatar
    Jan 04 2009
    Vancouver, BC
    x3
    Veteran Member Three Rings in2thenightaudi's Avatar
    Apr 03 2008
    '03 A6 2.7T 6MT
    San Diego, CA
    i think i remember seeing a DIY for putting an RS6 style fender vent into your stock a6 fenders. cant remember if it was here or on AW. if i remember correctly it consisted of taking something like a household air conditioning duct grate (where the ac comes out of the wall) and molding it into your existing fenders. ill look around this weekend to see if i can find that.
    EDIT: here's the linky
    -Nick
    OEM + 03 A6 2.7T 6-spd APR, 2Bennett, ASP, JHM, Hotchkis, Southbend, Mangaflow, SuperSprint, VMR, and some home-brew goodies
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    didnt you have a front mount?? why did you ditch it?
    Stage 3 SSP Tuned RS4 K04'd
    12.4 @ 115 on pump gas only
    425AWHP/467AWTQ
    ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
    95 Toyota Supra T51R 800hp
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    Quote Originally Posted by chrisbostonusmc View Post
    that's what i was thinking...
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Quote Originally Posted by in2thenightaudi View Post
    I just did that mod yesterday, I drove 15 miles to work and the hood felt as cool as it did when I left home.
    OEM + work in progress
