Originally Posted by
oneseba
Which makes the A4 a pig.
I'm looking for a technical discussion here. I know it works because it uses open differential front and back with EDL. EDL detects slippage and applies brake to the spinning wheel to force transfer torque to the opposite, torque transferred is dependent on ratio. This makes Quattro great in snowy conditions. However if there is no slippage at all (zero traction, ice or wheel in air) no torque will be transferred at all, if this happens on the rear the e-brake might be able to save you. But in normal road conditions, say turning, this causes understeer because of the front bias weight and the 50:50 distribution. This what the BMW Dynamic xDrive and SH-AWD offers and hopefully the new Quattro Torque Vectoring system will accomplish. All these systems are integrated with the vehicle's stability control, abs, traction control and this is where I get stuck, putting the pieces together. Hoping to get some input from our more technically apt members
First of assmonkey you don't know me, so lets not make stupid assumptions.
You are such a dumbass that somehow you equate the the fact that the Quattro system is mechanical and simple, and that somehow makes it a pig. The mass of the car and it's distribution is the only thing that affect the A4's handling.
If all four wheels are on ice then the system applies the brakes to control wheel spin to obtain the best traction available, if they all spin then they all get the same power (please remember even on Ice you have some traction). BTW if all of these cars are put on a sheet of ice which do you think will do the best.
You got stuck putting the pieces together because you as I stated before are a dumbass, the only difference between the systems you named are the electronic clutch in the center differential, but they all use the abs brake sensors and brakes to control wheel spin and transfer power. The quattro just does it mechanically, when the brake is applied the power is transfered.
