Results 1 to 24 of 24
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    JHM 01A 5-speed (B5/B6 -A4) Manual Transmission Rebuild kit and VIDEO now available!
    We just completed putting together the 01A 5-speed Transmission rebuild kit for B5 and B6 A4 5-speeds from 1996-2004. (Actual video comes on DVD and is 1 hour and 47 minutes long!) The video will be FREE with the purchase of any of our rebuild kits and only $25 SHIPPED in the lower 48 states if you don't need a kit yet. If you get the video separately and buy a kit later we will rebate you the $25 at the time of purchase of the kit. NOTE: Video was done on an O1E 6-speed (slightly different, but very very helpful info) and in combination with a Bentley Manual the rebuild should go smoothly.
    LINK TO THE KIT IN OUR STORE --> http://www.shop.jhmotorsports.com/pr...&productId=189
    Watch the DVD video Trailer HERE Actual video comes on DVD and is 1 hour and 47 minutes long! Video has been used by many B5 S4 owners to rebuild their more complicated 01E trans, do a search. Here is a link to one of the most recent threads on how useful my DVD was. http://www.audizine.com/forum/showthread.php?t=205310
    Link to the contents of the kit and recommended tools HERE
    Click Here for pricing on our 01A 5-speed rebuild kits and rebuild video NOTE: Make sure you check out the lower cost options by removing some of the not always necessary items from the drop down boxes at the bottom of the page in our store. (email us for other transmissions, we can get any. We can also quote you a price on a less complete kit if you are in a financial bind or feel you don't need all the parts, just email us.)
    CONTENTS OF THE KIT
    1 Transmission Rebuild Video on DVD (1 hour 47 minutes in length)
    2 Synchronizer Ring for 1st and 2nd
    2 Synchronizer Spring for 1st and 2nd
    4 Synchronizer Ring for 3rd, 4th, 5th and optional Reverse
    4 Synchronizer Spring for 3rd, 4th, 5th and optional Reverse
    1 Input Shaft Seal
    1 Selector Shaft Seal
    1 Rear lower shaft rubber
    2 Output Shaft Seal-front (optional)
    1 Upper rear case seal
    1 Rear case lower o-ring
    The B5-B6 A4 kit should look similar to this w different seals being the main difference.
    Click here to check out all our installation, track and informational videos
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Jan 25 2006
    A4 2.0T
    MD
    Re: JHM 01A 5-speed (B5/B6 -A4) Manual Transmission Rebuild kit and VIDEO now availab
    Holy shit thats expensive....... How much more if you actually need a gear or something?
    P.S. Nice work on creating the video.
    Feb 27 2005
    North Wales, PA
    the price isn't bad considering thats about how much a stock used high mileage tranny goes for. so for about 600 bucks you get a pretty much newly rebuilt tranny.
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by Don Supreme View Post
    Thanks.
    Unfortunately hard parts ain't cheap either. Unfortunately it just ain't cheap in general. Waaaayyy cheaper than a B5 S4 at least. I know used trannys for these cars are pretty cheap, but that is always a gamble and some people like to do it right. You can opt out for the reverse synchro and front output shaft seals and save $100+.
    I do have one good core for used parts as of now and will hopefully acquire others since the trans code decides your ratio.
    Quote Originally Posted by Poopie View Post
    Yeah after shipping you would get near that. But most people can probably opt out of the reverse synchro and front output shaft seals and save $100. I would agree with you. I like rebuilding my own trans that I know the history on vs. buying a used one which you know nothing of its history and will eventually fail anyways. Plus peplacing the trans again due to a bad used one is always a pain.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I was just about to make a post asking if anybody had a trans rebuild kit.
    You may be hearing from me soon.
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by jaybquick@JHM View Post
    Thanks.
    How much would you pay for cores?
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by djwimbo View Post
    Cool man. They have been quite popular with the S4 owners so far.
    PM me what you are looking for on it. Need the trans code off of it too.
    The thing that sucks is the shipping will jack the price up a bunch. Should cost a good $100 to $150 to ship it.
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    Do you have a rebuild kit for a FWD 99.5 B5 A4?
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Veteran Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    links dont work for me
    If I hit the switch, I can make that ass drop.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by ThatA4T View Post
    same here.
    here's the link that works for me
    http://jhmotorsports.com/shop/catalo...67c6dec714adfc
    $490 isn't bad at all. I paid $700 for my used transmission with 70k on it.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Jun 10 2009
    Denver CO
    i need a used tranny first my first gear is done...
    anyone with a used tranny in good condition pm me!
    Senior Member Two Rings ApeX-CrZn's Avatar
    Oct 14 2009
    B5 A4, mk1 rabbit, 84 Chevy S10,
    Bay Area , CA
    are these Synchros the same material/style of the oem ones? or are they an improved material like the s4 kit?
    Active Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    yeah links are old.. my tranny isn't very happy either.. doesn't pop out of gear but the synchros are shot.
    AEB B5 A4, QUATTRO MANUAL SPORT-H&R,FORGE,1BAR,5BAR,BOOM
    xbox live: Cr0tchf4i
    ["im in the computer lab and some dude with about 8" just sat down next to me -S4Jet"
    WWW.ASKMY2CENTS.COM
    Aug 13 2008
    Indiana
    I have 2 transmissions with bad first gears and 1 with bad synchro's as well. This kit helps me not at all =(
    -Nic
    Established Member Two Rings brockallentaylo's Avatar
    Apr 30 2010
    2007 530i sport, 2000 F350 CC
    Crescent, OK
    Man you people must shift with a lot more urgency than me. I have never worn out a synchronizer before even with 250K+ miles.
    "Hey, what kind of party is this? There's no booze and only one hooker"
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    does anyone know of a kit that includes a FULL rebuild? my 1st gear makes a lot of noise while i drive with it, and i think i read up that it's most likely a chipped gear. sadly, this kit doesn't include gears :(
    2001 Audi Allroad 2.7T, 2000 Audi A6 4.2
    2003 Audi A4 1.8T (sold), 2002 A4 1.8T (sold), 2001 A4 1.8T (sold), 2001 A4 2.8 (sold)
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    The actual gears are not cheap at all, just for 1 full gear set will cost you about the same as a good used 01A transmission. I have about 4 01A 5 speed transmissions that have a broken 3rd gear, the rest of the gears are good.
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by M-Hood View Post
    god damn that's a lot! so it's kind of pointless to rebuild this transmission then? i just really want a transmission that shifts buttery smooth, but if it's going to cost that much - a may as well have gotten an S4 instead of an A4.
    Feb 08 2011
    Quote Originally Posted by BlazinB5 View Post
    S4 transmission is far from buttery smooth, no where near as smooth as the 01A.
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    I would go with a replacement.... Go on mnaudi.com (forum) and there are a couple part outs going on right now... dont go with the s4 6 speed, you need a lot of different components to make it work on an a4.... btw I got a replacement transmission that i bought off of a local part out installed at NurTechnik near the Cities (see you are from forest lake!) My shifts are now muuuuch better. (I blew my 2nd gear on mine last fall) Great guys at NurTechnik, and great pricing.
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Apr 22 2007
    Riverbank, Ca
    No kits will include gears. Gears need to be inspected upon teardown and replaced as needed. Contact JHM for actual prices or call your local audi dealer. You'll probably looking at over 500 for a gearset, maybe more. Thats pretty standard.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Aug 27 2013
    United States
    question is there anyway to tell if the stock transmission is still in the car. for example is there a stamp anyway that has the vin numer on it or anyways to link it to the car?
    Mar 13 2009
    05 S4, 98 A41.8tQ, 84 Scirocco
    Gaithersburg, MD
    It may be more than $500 for a 1st gear set since the input 1st and 2nd gears are integral with the input shaft.
    I got lucky and picked up a transmission from a friend with a blow torsen, but all the other parts that I needed were good.
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    So how long would it typically take to rebuild an 01A from a 99 a4 1.8tq? Are there any special tools needed? My Chilton's manual scared me...
