Results 1 to 40 of 45
    Stage 3 Forum Advertiser Four Rings VMRSport's Avatar
    Apr 25 2008
    Irvine
    VMR Sport | B5/B6 Audi A4 Test Pipe w/ Heat Shield - New Design
    Stainless steel test pipe made for the Audi A4 1.8T, from 1996-2005 and VW Passat 1.8T 1996-2001.
    Hey guys,
    This is a brand new test pipe design that we just came out with. It is made specifically for the B5 and B6 A4s. Our test pipe is that our test pipe was designed to look and fit exactly like an OEM piece.
    An advantage to our test pipe design is its ability to minimalize the amount of heat that gets transfered from the cat into the engine bay. We were able to accomplish this by designing a shell around the pipe. Our shell's design is a better alternative to the conventional heat wraps that people use.
    Again, just to clarify, this is not a real cat, and is not intended for use on the streets. This is a straight pipe that is designed for off-road use only.
    Pricing will be $199 plus $15 dollars for shipping.
    We currently do not have this up on our site yet, so if you are interested in ordering, please go ahead and send payment to our paypal address:
    [email protected]
    In the notes/comments section, include a link to this thread, so that we know what the payment is for, and any other information you feel necessary.
    The benefits from running our test pipe includes:
    Removes unwanted exhaust backpressures caused by the restrictive stock cat
    Inproves the turbo's efficiency and allows it to perform better
    Increase both power and torque
    Allows for higher sustained boost pressures
    Faster throttle response
    Capable of supporting the air flow for up to 450hp
    Flanges have been casted and welded both inside AND outside, to ensure long term durability
    What you will get with our kit is:
    Stainless steel test pipe, with oem design and fitment
    High quality stainless steel bolts and nuts
    Test pipe to down pipe metal exhaust gasket
    Downpipe to turbo gasket metal exhaust gasket (Other test pipes do NOT include this)
    1-year limited warranty
    If you have any other questions regarding this product or anything else, feel free to PM or e-mail me at [email protected]
    thanks.
    -Don
    [email protected]
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    Re: VMR Sport | B5/B6 Audi A4 Test Pipe w/ Heat Shield - New Design
    What is the pipe size on this?
    Drew-
    2013 Audi S4
    Apr 25 2008
    Irvine
    2.5" Inner diameter.
    -Don
    This box does not currently receive PM's. Please direct all inquiries to Charles (VMRWheels) or Peter (Peter@VMRWheels).
    VMR Sport | Integrated Vent Gauge Kit
    B7 Audi A4 Test Pipe - $69.99
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Will it throw codes?
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Apr 25 2008
    Irvine
    If you have stock software, it will throw a code, but not if you chip it.
    -Don
    Senior Member Three Rings Jersey Anthony's Avatar
    Jan 17 2008
    2006 A4 2.0T Q M S-LINE
    Jersey
    any for b7 yet?
    • Automotive Tailors
    • Velocity Motoring
    • D2 Racing
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    Quote Originally Posted by VMRSport View Post
    Is this on the underside of the unit? Basically asking that no "official" will see it when inspecting the car for a "legal" cat?
    Do you have a need for speed? Then drive it like you stole it!
    Apr 25 2008
    Irvine
    There's currently nothing available for the B7 yet.
    For the stamp, I believe it is facing away from you, when viewing it from the front.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Its a little hard to make out from the pictures but does it have both bung orifices for the front and rear o2 sensors?.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Apr 25 2008
    Irvine
    Yeap, it is on the other side, in the first picture, you just can't see it there.
    -Don
    Apr 25 2008
    Irvine
    Ok, as far as figuring out which direction the off-road use piece faces, I am going to confirm with one of the guys who bought one from us, once he installs it.
    Senior Member Two Rings tonelee1316's Avatar
    Oct 11 2006
    rancho cucamonga
    ER testpipe comes with the Downpipe to turbo gasket metal exhaust gasket
    Genesis Autosport
    Evolution Racewerks
    Apr 25 2008
    Irvine
    PMs and e-mails replied to.
    thanks.
    -Don
    Apr 25 2008
    Irvine
    Looks like the For Off Road Use Only stamp faces upward, however, there are many ways which you can cover it up, if you don't like the way it looks. Simplest way is to have a small sheet of metal tack welded on there, or maybe a sticker would work, if it could stand up to the constant heat.
    I noted this in another thread that I made, in a different section, but the OEM heatshield was designed to function as a heat shield, and to keep heat away from the rest of the engine bay's components. It was also designed to give a OEM fit and finish look to the car, once installed.
    We tried looking at other places to put the stamp, but it just wasn't possible. Trust me, if we could have, we would have done it.
    Let me know if you guys have any other questions.
    -Don
    Apr 25 2008
    Irvine
    thanks all.
    -Don
    Apr 25 2008
    Irvine
    Thanks for the orders.
    -Don
    Apr 25 2008
    Irvine
    bump
    Feb 19 2008
    Akron, OH
    Anyone running one of these yet? any feedback?
    Apr 25 2008
    Irvine
    Yes, there was a B6 guy, who purchased a test pipe from me, including several others.
    What questions did you have?
    thanks.
    -Don
    Apr 25 2008
    Irvine
    thanks.
    -Don
    Established Member Two Rings A4DJ's Avatar
    Apr 22 2008
    '05 S4
    Colorado Springs
    thanks.
    -Don
    Just some real-life feedback from someone with an APR chip on whether or not it threw any codes. Very interested since i'll be replacing my exhaust soon.
    Apr 25 2008
    Irvine
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    Do we get a special GB price with a certain amount of people?
    Also, if i were to drive down there, would you guys install it...
    (Ka-La-Bre-Ah)
    Apr 25 2008
    Irvine
    We do not do installations.
    We also aren't currently offering any GB prices for these right now.
    thanks.
    -Don
    Apr 25 2008
    Irvine
    bump
    Mar 27 2005
    The Cold North
    Quote Originally Posted by A4DJ View Post
    If you get the cat-delete software version from APR you will not throw a code.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Apr 25 2008
    Irvine
    Yea, a good way of getting rid of the CEL is by getting it tuned/flashed out. It is also a good idea to do that anyways, to fully optimize the test pipe.
    thanks.
    -Don
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    pretty slick. too bad the stamp faces upward...and that im not looking into testpipes right now.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Apr 25 2008
    Irvine
    Thanks.
    We are always looking for feedback on our products.
    -Don
    Apr 25 2008
    Irvine
    PMs replied to.
    thanks.
    -Don
    Apr 25 2008
    Irvine
    PMs replied to.
    thanks.
    -Don
    Apr 25 2008
    Irvine
    All items are currently in stock and ready to ship out.
    thanks.
    -Don
    Senior Member Three Rings A4B603's Avatar
    Jan 30 2007
    Corona, NYC
    just ordered mine hope to get this soon. How long are your shipping methods 2 nyc.
    2003 A4(B6) 1.8T Sports Package
    FWD CVT
    MagnaFlow Exaust / Awe Boost Gage / Debadged / RNS-E / HKS SSQ BOV / 032 motor mounts / Carbonio V2Intake / Caractere Grille / Vagged / RS4 side Engine Cover / 1200 watt Kicker Solo Barrick 08 & Cap / Skidplate /StopTech 332 BBK / Sportec Rear / Apr Stage 1+ (apr inj.)/ VMR Sport Test Pipe / VMR 19" Rs4 Reps(gunmetal) / Falcon 452 235-35-19
    Apr 25 2008
    Irvine
    We ship things out via USPS priority.
    -Don
    Active Member Two Rings AudiDWK's Avatar
    Mar 20 2008
    2005 B6 A4 1.8T
    Cerritos, CA
    Hi - not sure if this was mentioned earlier - pardon me if it was - but about how much hp/tq gains could I expect with this? I'm chipped with k&n drop in filter.
    thanks!
    Apr 25 2008
    Irvine
    I would say from the pipe alone, I would expect anywhere around 10-15hp, if not more, especially with a tune/flash done.
    Let me know if you have any other questions.
    thanks.
    -Don
    Mar 20 2008
    2005 B6 A4 1.8T
    Cerritos, CA
    Is there any difference in performance b/t this and the straight stainless steal one? Also, how much difference should I expect in sound?
    thanks!
    Apr 25 2008
    Irvine
    Both obviously flow the same, since they have the same inner diameter pipe.
    The major benefit from this over our other design is that this incorporates a heat shield, which helps keep the heat out of the engine bay and in the exhaust instead. It also gives a nice OEM look, once installed.
    -Don
    Apr 25 2008
    Irvine
    thanks.
    -Don
    Dec 08 2007
    Easton,PA
    how come the regular ones arent for sale on ebay anymore the only ones i see are for b7? i need one for a b6
    2002 A4 1.8t 5 speed maunal-revo stage 2
