2 Attachment(s)
DIY: Motor work, Timing tensioner or anything with the motor and front end
Dont think it gets easier with 8.5 either. They even took the screws away. I broke 3. Found out though you can push the pin right through. If you can find the pin after you can reuse it.
Sent from my iPhone using AudizineAttachment 89627Attachment 89628
You don’t have to remove the crank to do pistons, at least not on older 1.8t/2.0t engines. You remove the head, drop the pan, then unbolt the rod caps and pull the piston and rod out the top. I’m re-ringing my pistons and that’s what I plan on doing. I have a spare engine on a stand so I’ll have it out to rebuild it then just swap with my existing engine when it’s ready to go.
There might be a procedure in ELSAWIN I could dig up. They often have stuff like that and you can save it in PDF format.
I can see what I can find. I might need some specific info on your car for elsawin to find the correct car configuration though so if you want to shoot me a PM I can probably get it figured out.
When I did my clutch on my b6 I got some tall jack stands and was able to drop the trans and change the clutch. Unless Audi has significantly changed how they mate their engines and transmissions, I would expect unbolting the trans is very much doable with the drivetrain in the car but I wouldn’t stake my life on it.
I’ll see if I can pull up a procedure for engine removal for you. I may need a VIN but i might just need year, model and engine size. If you don’t mind posting that info that would be helpful. Obviously don’t post your VIN but I might need that, and you can shoot that through PM if you’re okay with that. I’m a trustworthy person.
