Awesome thanks
Printable View
Awesome thanks
I picked up a set of these when I did my chains to help clean up the RTV surfaces.
https://www.amazon.com/Dico-541-778-...2875077&sr=8-8
Since they are basically plastic then they don't gouge into the metal.
I ran into the same problem for bolts from FCP when I did mine.
Here is a list off the top of my head that I changed
Cam adjuster bolts
Timing chain cover bolts
Flywheel bolts
torque converter bolts
front axle bolts
Big ass bolt at the hub
rear drive shaft bolts
Center bolt for motor mount
The book says the aluminum bolts that hold the trans on the engine can be reused once. I was able to reuse all but 1 bolt. Had 1 bolt snap in half.
The book calls for new o-rings for all the coolant connections so I changed those as well.
Anyone know which head gets the longer timing chain? 1-3 or 4-6? I want to put the timing chain cover on before I install the heads. I want to make sure I get a good seal
If you still have them with the packaging you can look at the FCP website to match up part number with side
06H198401A Are these the same of the EA 888 engine?
Came across this thread again - very curious how the Chinese parts from that rebuild kit are holding up.
