3.0T A6 Build "Klaus" -> 3.2T build
In 2023 I picked up a cheap 2012 3.0T A6 from down the street. Wife already named it Ruby. Had a cracked engine block from water/ice expansion. Broke the PCV as well. Drove it home with the throttle body unplugged... Little JB Weld on the block and a good used PCV swapped in, and she runs and holds temp.
I have since swapped the seats, HVAC Head unit, supercharger, driver fender, front bumper and the LED headlights to my daily 2013.
My "plan":
- 3.2 FSI block for the rebuild
- CTUB heads
- 84.5mm sleeves for 3.1T
- CTUB rods - re-bushed for 20mm pins
- CALA pistons
- CREC supercharger with CTUB innards.... no clutch, bigger coolers.
- Separated chilled water system
- CTUB ECU tune to be determined
- 14point7 SLC2 w/LSU 4.9 wideband
- Supplementary fueling ecu
- CREC Intake Manifolds with MPI
- TCU tune to be determined
- Bigger supercharger later, but already in hand.
- DI injectors to be determined
- MPI injectors to be determined
- Interior removal
https://hausofdub.com/g3/var/resizes..._132533764.jpg
https://hausofdub.com/g3/var/resizes..._202135855.jpg
https://hausofdub.com/g3/var/resizes..._215702052.jpg
https://hausofdub.com/g3/var/resizes..._170033803.jpg
3.2 delivered
https://hausofdub.com/g3/var/resizes..._191049402.jpg
https://hausofdub.com/g3/var/resizes..._223849079.jpg
https://hausofdub.com/g3/var/resizes..._223901643.jpg
It's cool to say I am crazy. I am. Also building 3 cars at once [drool]
