Results 1 to 7 of 7
    Established Member Two Rings dspl1236's Avatar
    Dec 15 2007
    '90 90q 2.6, '90 GTI 3.6, '12 A6 3.2T
    Akron, Ohio
    1990 90q 2.6 20v
    Hello All,
    This is my 1990 Audi 90 Quattro 2.6 stroker build. I purchased this 90q 2.3 20v with a buddy to fix and flip.... ended up just buying him out to build the car for myself.
    I wanted todo a short deck 20v stroker, very little info is out there but is doable. Had to-do some block craving to clear the rods and do some piston massaging due to old vs newer valve offsets.
    Parts list so far:
    2.3 7A block - rod clearance die grinding needed
    2.5 AAF crank
    2.3 7A head and cams
    2.0 CCTA rods/pistons
    12.9 Main bolts
    2.5 AAF oil pump
    Early 7A Bag-O-Snakes header w/vband
    034 Motorsport 7A injector adaptors
    034 Motorsport Silicone block breather
    034 Motorsport Delrin Engine mounts
    034 Motorsport Density Transmission/Diff mounts
    034 Motorsport Delrin rear diff mount
    034 Motorsport Rear Delrin Control arm Bushing
    034 Motorsport Aluminum subframe bushings
    034 Motorsport Polyurethane Snub Mount
    Powerflex Black Series front control arm bushings
    New Febi Inner and outer tirerods
    New rear control arms
    Bilstein Sports Struts/Shocks
    H&R Sport Springs
    Stainless braided clutch line
    B3 Euro Headlights w/city light as blinkers
    14point7 SLC Free 2 with LSU4.9 wideband
    Volvo S60 injectors
    034 Reman crank dampener
    Ebay RS2/S2 Aluminum Radiators
    G60 Calipers
    Brembo sedan front rotors 276mm
    Mako Driveshaft Center bearing
    Mako Driveshaft CV's
    Verkline Top Mounts Front
    Verkline Rear Track Rods w/ ARB
    Febi top mounts Rear
    New wheel bearings
    New Empi Sedan 20v front/rear CV shafts
    HEL Stainless Brake lines
    MST MT13 15x8 et20 with Lexani LXTR-203 205/50 R15
    Over the last few years I have been collecting parts and putting together the motor.
    Runs off a bucket of gas
    https://youtube.com/shorts/npcSPItkE...fmnwuvdCGf_Fbr
    '13 A6 3.0T + '90 Jetta 2.0T 20v + '92 Corrado SLC + '90 90q 2.6 20v + '90 GTI Plum 3.6 VR6 + '89 200 10vt + '12 A6 3.2T + '01 A8
    Gone: '91 200TQA, '90 V8Qm, '97 A4 1.8T, 2x '98 A4 1.8T, '90 80Q, '90 CQ, '91 CQ, '91 CQ 1.8T, '91 200TQ, '95 90cs, '01 Jetta 1.8t, '08 Passat 2.0T, '13 GLI, '76 Audi Fox, '04 1.8T USP
    Dec 15 2007
    Akron, Ohio
    The other weekend I pulled the whole rear end to refurb. New wheel bearings, axles, etc. Found what I believe is the last set of reman G60 calipers in the county. All new pads and rotors on the way. Ditching the oem mesh 14's wheels and swooped up a set of cheap knock off mesh 15x8's 4x108 and 4x100 to share with my mk2 Jetta.
    I have been eyeballing the Verkline subframes...
    Dec 15 2007
    Akron, Ohio
    Been slow to update over here. 90q is on the road!
    Phase 2 Begins...
    Dec 15 2007
    Akron, Ohio
    Off to storage to sleep with its brethren.
    Dec 15 2007
    Akron, Ohio
    Just kidding. Got an alignment for snow fun.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Great info on what's needed to build this. Makes me want to sell my spare AAN and just build the 7A I have in my CQ. Thanks for sharing!
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Dec 15 2007
    Akron, Ohio
    I do plan on building a 2nd 7a into a 2.6. The 2nd time around I plan on different pistons I would prefer not to carve them up as much as I did.
    A 92.8mm crank would be dang near drop in with these tsi rods and pistons. That gets you 2480cc.
