I wanted to share another carbon build up issue and have already posted this in the Audi FSI Engine Carbon Build-up Megathread in the Transmission & Drivetrain Forum.
Here’s another data point. This is my first post and unfortunately it doesn’t have anything good to report…
Vehicle Make/Model: 2008 Audi A4 3.2L
Mileage/Date: 11,990 miles / 30 November 2009
Oil used: Unknown. Dealer Supplied
Oil Change Interval: Average every 2850 miles*
Fuel Used: Chevron Supreme Techron (91/92 octane) or Shell V-Power (91/92 octane)
How short/long are your trips on average: 6 to 30 miles
Reported rough idle when cold to the dealer. CEL was on. Did not notice any loss of power.
Dealer invoice states:
“Verified Customer Concern. Hooked up scan tool, found five random engine faults. P0300, P0301, P0302, P0303, and P0304 (random cylinder misfire, cylinder misfire 1-4). Followed TSB 2019948/3, added fuel additive and road tested vehicle for 60 miles sustaining high engine RPM. Allowed vehicle to sit for several hours to repeat cold start up. Hooked up scan tool and cold started vehicle, MVB 14 registered 8 faults (4 in cylinder 1, 2 in cylinder 2, and 2 in cylinder 3). Will open TAC ticket. --- (Tech 2751) opened TAC ticket. They said to check camshaft adjustment. Performed check through MVBS 90-96 and they are fine, there are no sticking adjusters. Removed intake manifold and found carbon build up on back of valves. TAC said to perform cleaning as stated in the TSB. Cleaned valves, removed spark plugs, blew out carbon chunks. Reassembled and test drove. Let sit outside overnight and started cold. There was no misfire on any cylinder. Performed oil service per TSB. Closed TAC ticket. Done.”
Note:
Vehicle purchased new with 49 miles / 27 September 2008
Engine (short block) replaced for cylinder wall scoring 6521 miles / 14 April 2009
*Oil change interval shorted by engine replacement
Drove the car from Seattle to San Francisco and back. It currently has over 15,000 miles on it and its starting to run rough when cold again. Thank goodness for warranty!
