Originally Posted by
767Driver
I have been running a can of Sea Foam through my fuel system at about 2,000 mile intervals in the hope it will help with reducing carbon issues.I also only run Shell 93,Chevron or Texaco 93 gas and drive the car aggressively.
1) IS this frequency alright for the RS 4 motor?
2) Is there really any benefit?
3) The can also says you can use it directly into the oil system with the proper dilution. I am a bit hesitant to do this. Is this safe and a good practice? Thanks for the input!
Answers:
1) I would not introduce strong chemicals such as seafoam to fuel nor oil. Such procedure would do nothing for the CB on the back of the intake valves. It might keep the injectors and the upper area of the CC clean but that is about it. I am sure there are other options that are more "nice" to the
internals of the RS4 engine. Once this chemical and contaminants are introduced to the oil via fuel dilution, it will start braking down the oil properties at an accelerated pace and of course that would open a whole other can of worms. If you were to do it plan on doing an oil change soon after.
2)Some, there are better alternatives for such applications (cleaning injectors and upper parameter of CC). I believe the Audi dealer has an additive that people seem happy with.
3)I would not recommend this.
