Results 1 to 11 of 11
    Veteran Member Three Rings AndreNY's Avatar
    Apr 06 2005
    Boston MA
    Had issues this morning with starting the car
    i have read this somewhere here the first week i got my S4, someone was complaining that they have a problem starting the car in the morning when it's too cold. Well i have had a few of those but what happes it it usually takes about 2-3 seconds for the car to crank up. This morning we had the coldest morning this year in the low 20's and i first tried to start it held the key in for almost 5 seconds, NOTHING, second try 3 seconds still nothing, then after the 5 tries, and almost 4 seconds the car cranked. Is this really a common and normal thing on our cars when it's cold outside? If not what could it be,
    thanks
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: Had issues this morning with starting the car
    We had a fabulous high of 1 degree this morning and 15 below with wind chill.
    It is now 6 degrees and im glad my Audi is sitting in my garage.
    Sorry I have no useful information just wanted to bitch about how freakin cold it is outside.
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    all depends...when was the last time the car was used? was it parked outside? how much gas do you have in the tank?
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Four Rings EuroB6's Avatar
    Nov 24 2005
    2024 Audi Q7 2017 911 GTS
    New Jersey
    ^^true..i personally have never had an issue with either of my S4s....i started up my car this morning and it sat for 3 days of non-driving. When you try and start it next time, turn the key to the on position, wait about 3-5 seconds, then turn it on, see if that helps.
    2020 Audi SQ7 PremPlus | Navarra Blue|Black|Black Optic Package| 22” Forged Black RS Performance Wheels
    2024 Audi Q7 PremPlus|White|Beige|Black Optic Package
    2017 Porsche 911 GTS Black | GTS Interior Package | Numeric shifter | GT3 RS Skirts | Kline SS Headers, Kline 200 Cell Cats, Kline SS Exhaust | Full Car PPF | 20” BC Forged MLE81 | Michelin PS4S |TechArt Springs | Vektor Performance Oil Separator | BMC Air Filter
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Quote Originally Posted by EuroB6 View Post
    This deserves an explanation... When you're turned to the "on" position, your electrical system is turned on, and subsequently your fuel pump pressurizes the system. If you're car has been left sitting for several days, the pressure in the system drops a lot more, especially if these are cold days.
    BUT I think these cars are still too new to be having any starting issues for any reason.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    It has to be something with the ignition switch or some sensor (crankshaft position sensor maybe?) acting slowly when it is cold.
    I have the same thing happen to me. Push in the clutch and nothing. Turn key off and repeat a few times and it starts. Hasnt done it in a while because it hasnt been too cold but tomorrow I bet it will occur.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Apr 14 2004
    rs4, ruf, rs7
    L.A./Vancouver
    Do a search on Audiworld. I believe its been discussed. Most likely the ignition switch needs replacing, apparently it dies a slow death.
    Apr 06 2005
    Boston MA
    ^^^ thanks i will look into this
    Im almost sure it has to do with how cold it is. Yesterday when leaving work it was in the low 30's the car fired right up. This morning we had our coldest day this season about 10 degrees, and it took almost 10 tries for the car to start. Everything turns on but the car will not crank. It does make sense that the ignition switch would cause that, but why is it only doing that when it's really cold??
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Several have had similar problems...mine turned out to be the starter. It got progressively worse over time and as the weather got colder. The dealership finally replaced the starter and no issues since. I'd try a search here and AW. I just tried a search here and the search didn't seem to be functioning .
    Here's a few threads I found @ AW...
    http://forums.audiworld.com/s4b6/msgs/421030.phtml
    http://forums.audiworld.com/s4b6/msgs/422690.phtml
    http://forums.audiworld.com/s4b6/msgs/421486.phtml
    Keep us updated...Steve
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Feb 26 2006
    4 degrees in Hartford this morning and car took 2 tries to start after sitting out overnight. B6 S4
    Veteran Member Three Rings Blue04's Avatar
    May 28 2005
    2015 Q5 2.0T, past 2004 S4
    Long Island, NY
    I had this problem. The last thing they did was the starter and it fixed the problem. They changed both clutch switches, some relays and nothing worked. The starter was the problem. If you cant start the car you can hook up jumper cables to start it. You dont even have to let it sit and juice up, once you hook them up it will start right away. I actually kept a trickle charger in the trunk so i didnt need another car when it wouldnt start. Its definitely working fine now though
    2015 Q5 2.0T
