Results 1 to 23 of 23
    Forum Moderator Four Rings docurley's Avatar
    UK London
    SP51X (Hybrid K04-15)
    Well after buying a Dead K04-15 from Canada for $200 I now have a rebuilt Hybrid K04-15 SP51 nickname Outlaw.
    And here she is
    Plan are to fit her in two weeks time before I go on holiday (finger crossed) and then when I get back to install my secondhand Stage III southbends Clutch ($100) providing I sort out a single mass flywheel.
    Once this is done custon Exhaust will be on the cards before a Remap.
    I have big hopes for the turbo so we will see how it goes.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    Re: SP51X (Hybrid K04-15)
    Looks sick! But isnt a stage3 clutch a tad overkill? what did the rebuild run you?
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    this should be interesting to watch, ^^no stage 3 i think would be a perfect clutch for the K04, its not just horsepower that destroys clutches, torque does to. Since you are the first to do this on the board you are definitely going to have to dyno... Good luck
    ::2002 S6
    UK London
    Well after the cost to buy the dead turbo it was $650 for all the work which meant all the internals are new with K04-23 shaft turbine manifold & compressor housing shaft, this shaft is found specifically on Audi Motor sport cars so the upgrade requires re-profiling of the turbine housing to accept the larger K04-023 turbine shaft.
    The K04-023 has approximately 3mm larger inducer compared to the K04-015 sharing the same exducer.
    In addition this upgrade includes the over-sized SP51X compressor wheel, updated Bearing Housing with "twin-feed" oil channels.
    Sean K:
    Your turbo is new, we don't use regenerated components on SP51 projects.
    Everything is new except for the turbine manifold & compressor housing.
    The car will be setup on a rolling road so dyno figures will be posted once every thing is done and funds permitting that is but Im looking for around 270bhp based on the facts 225TT with the K04-23 turbos can be mapped to 280bhp without any mods bar exhaust.
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    keep us posted! this sounds like a fun little project! what were you planning on using for tuning? j31 + lemmi tweaks?
    The harder I practice, the luckier I get.
    - Gary Player
    UK London
    I don't have a clue about mapping so I’m having it custom mapped on the rollers by a pro as we don't get any K04 file here as our fuel is slightly different to yours so every thing tends to be custom although I would think the company will keep a copy of the file for future tunes and a good base map once done.
    One thing I need to find out is what the stock injectors can handle as I'm not sure if our injectors are the same rating as the US but I do know we have 4bar FPR as standard compared to your 3bar so I may just have it mapped with the standard setup.
    Another note is that I run a AJL engine which is DBW on a 2000 which you guys will find strange plus I don't think you got the AJL engine in the US either.
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by docurley View Post
    US came with 4bar standard as well.
    ATW was DBW in 2000 in the US, but no AJL in the US.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    It will be fun to see what we can get out of these, as mine will be here next week after i destroyed the sp15 with the jubilee clip. They have rebuilt it to the above state like Docs.
    I am also dbc, but currently running an APU engine with an AEB head/manifolds, again i don't think you have the APU DBW engine over there either do you?
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    impressive k04. incredible how they stuff that size comp wheel in there.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Quote Originally Posted by Mawhitey View Post
    no. our motors are 97-99 aeb, drive by cable, big port. 2000 atw, drive by wire, small port. and 2001, awm. drive by wire. small port.
    aeb and atw share the same internals, misus the cylinder heads of course. but they are both i/m shaft driven oil pump and 20mm wrist pins.
    awm uses a chain drive pump. w/ 19mm tapered rods.
    contact via email please.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Quote Originally Posted by creechsa4 View Post
    as impressive as ATP stuffing a GT2871r compressor wheel into a GT28r housing.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Jan 20 2005
    99 AJL TQS
    UK
    Mine is here now also, so i thought i would update the pics to include the compressor turbine shape and the machining on the exducer side.
    For shits and giggles, comparison between a k03 and the SP1x
    -Mark -
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Such a cute little turbo
    Jan 20 2005
    99 AJL TQS
    UK
    That she is its a Baby Ass Turbo...... he he he
    -Mark -
    Senior Member Three Rings cpu77's Avatar
    Feb 27 2004
    Mansfield Ohio
    UPDATES!!!!!
    So how did this project turn out?
    Current
    2004 Silver A4 1.8T FWD 5spd Franken Turbo/3"Exhaust/Racewerks FMIC/440cc/Motoza/TestPipe/SAI Delete
    2004 Red A4 1.8T FWD 5spd (Wifes) Mods- Stage 1 Plus APR w/Neuspeed Exhaust/Test Pipe
    2002 Black Porsche 996TT X50 UM Stage2 Z/C k16/24 528AWHP
    1999 Wrangler 4.0 5spd/2.5" Lift 33" Tires No doors No top!(I like driving this better than my 911)!
    Jan 20 2005
    99 AJL TQS
    UK
    -Mark -
    Apr 22 2007
    Riverbank, Ca
    You have cracks on the exhaust side... See the small separator? one big crack one small crack.
    My old KO3 is the same way, but worse. Made a crazy ticking noise
    UK London
    Oooh never saw that before.
    Jan 20 2005
    99 AJL TQS
    UK
    I was assured that it was ok to use, and its making good power etc with no ill effects. As they had to machine the housing they checked it thoroughly I always cool her down properly so hope it wont get any worse
    -Mark -
    Apr 22 2007
    Riverbank, Ca
    Well, Honestly good luck. Im really surprised they let that fly. The crack on the left will open up into the atmosphere soon, mine did. Sure i could hold boost the same, but for how much longer? It made a crazy ticking noise under boost at high RPM's.. Im 100% positive it was and exhaust leak out of that small area.
    Anyways, Good luck! I hope it last many more miles! You can probably get it tig welded up...
    Jan 20 2005
    99 AJL TQS
    UK
    thanks for the info, i hope it will be ok too
    -Mark -
    Jan 21 2008
    Tucson
    You might consider grinding the crack down to solid and creating a smooth radius. That might prevent any further creepage.
    Apr 22 2007
    Riverbank, Ca
    The crack on the right is about 1" deep.. I dont think thats an option for him.. Also his is installed already..
