Results 1 to 27 of 27
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    DIY: B6 Glove Box Bracket
    So here is the Deal on the Glove box DIY
    (I have successfully completed this with hand tools poor quality tho)
    Tools
    -Pliers
    -Hack saw
    -Drill of some sort, Drill press is best
    -At least a Dremal( angle die grinder or Bench grinder)
    -table Vice
    -1/16 drill Bit and a Counter set Tip
    -Body Hammers
    Materials
    -1/2” X 4.75” Flat steel (found at lowes)
    -4X ½” machine phillips screws
    1. Remove the Glove box door. It is Two metal pegs and a plastic damper piston that slows the doors release.( I did the Glove box Piston Mod too) http://www.audizine.com/forum/showth...=glove+box+fix
    2. Saw a piece of flat steel 4.75” long.
    3. Mesure about 1” down and Place in a vice as square as you can. Hammer this into a 90 degree angle.
    4. On the short leg measure a quarter inch and draw a line.
    5. Saw along this line.
    6. Once you trim the small piece off, place the short leg of the bracket into the vice at about 5/16” slightly hammer to form this shape.
    7. Then place the long leg into the vice at about 1” and then about 2.5” hammer slightly into the desired shape. ( the goal is to copy the Contours of the glove box)
    The desired shape
    8. Work with the bracket until it fits nicely on the glove box door.
    9. Once its bent into shape, Sand/Grind the mess out of it to make it smooth and eye pleasing shape.
    10. Once you get your shape drill four holes in the bracket around theses points.
    11. Counter sink the holes
    12. Now Paint
    13. Next attach the bracket to the glove box door, don’t forget to pre drill for screws .
    14. Now reassemble and be happy you don’t have to buy a new door!!
    LINKS:
    http://www.audizine.com/forum/showthread.php?t=160782&
    http://www.audizine.com/forum/showth...ight=Glove+box
    http://www.audizine.com/forum/showthread.php?t=301053
    Good Install Instructions
    Hope this helps,
    Fritz
    Sep 07 2007
    Atlanta GA
    Re: DIY: B6 Glove Box Bracket
    ADMIN: would you please move this to the appropriate Section i couldn't figure out how to post it in the DIY section...
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    can't wait to put mine in they look great just couldn't figure out where they screw into. Whether I have to somehow remove the broken plastic from inside the box or screw into it.
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    So i guess this is a common issue...
    Mine is broken as well
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    isn't it covered by warranty...i got mine fixed by the dealership under warranty
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
    Sep 27 2008
    Orlando, FL
    Might be for you since yours is an 05 but for me im screeewed haha.
    Jan 12 2009
    MD
    Quote Originally Posted by ILikeBigBrakes View Post
    Hey man did you figure out where to drill the bracket into?
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Home Depot has a bracket that fits the glove box exactly. It's bent at 90 degrees you just have to shape it.
    High speed Ferrari movement...
    Sep 07 2007
    Atlanta GA
    sweet boosted what is the brackets item number?
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Def need to bracket number, I will do this as soon as I get those
    This issue pissed of off Royally, its such as simple design flaw
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    maybe if you plasti-diped it, then it would look more clean
    Sep 07 2007
    Atlanta GA
    yeah they would be glossy but the flat black is almost a perfect match to the surrounding plastic. thats why i use the paint I do.
    Established Member Two Rings brandn3w's Avatar
    May 09 2009
    z
    Thank you!
    I think easier way would be as someone mentioned the 90* brackets at Lowe's/Home Depot. They already have holes and bent so really just shaping, spraying, screwing is it. Disadvantage are sometimes the holes are quite large, but nothing a washer can't help. ;) Good deal, guys!
    Sep 07 2007
    Atlanta GA
    Wanna Fix your Glove box?
    i make brackets to fix your Broken Glove box. PM for Pricing!
    DIY/Info
    Aug 21 2010
    CA
    Pulling the of the glove box cover
    So really dumb question. I'm fixing my glove box because the hinge box but I'm having a hell of a time removing the pin in this picture. I can turn the pin but I can't pull it out. Any tips? was it easily removable for you? do i have to put a lot of muscles or something?
    thanks
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Quote Originally Posted by cbdrake View Post
    thanks
    Sounds like it's going about right. I ended up using a hammer on the pliers to get it out, and it still took a while the first time. Just keep trying and get a little creative if necessary.
    Aug 21 2010
    CA
    Quote Originally Posted by CardFan View Post
    well i got one pin out but the second one is really stubborn. are there replacements for these pins that I can pick up at Home Depot or some where? I'm stripping the tip on the second one.
    Senior Member Three Rings MoRbiD's Avatar
    Sep 06 2004
    2005 Audi A4 1.8TQ 6MT
    Rochester, NY
    You can only get the replacement pins from Audi Parts. They aren't expensive, I have the part number laying around somewhere if you need it but the Parts Department can look it up too.
    To get those pins out you have to pull and wiggle em at the same time. Audi used some kind of thread locking stuff on them when they went in at the factory.
    I used a pair of needle nose pliers with a long handles. CardFan has the right idea too but like I said pull and wiggle side to side. The pins are metal and won't break.
    As a aside you don't need to get them all the way out to take the Glove Box Cover off. Just enough so it clears both sides of the mount for the cover.
    USP CLUB MEMBER #3399
    Veteran Member Three Rings S4King's Avatar
    Aug 01 2009
    Houston, TX
    Pics need to be re-hosted.
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    pic's need fixing...
    whats wrong with jbweild, thats what i just used on my broken glovebox....
    couldnt get those damn pin's out so i had to do it with the door still attached ... pita,
    also my piston thing broke so i need to get a new one of those.....
    really interested to see what this diy is actually like with pictures ....... maybe i can redo mine.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Veteran Member Three Rings ReniA4's Avatar
    Jun 26 2009
    Clearwater, Florida
    same here man,trying to see those pictures but they not there,any possibility u can email me or post em up again
    "Reni"
    Maya Stm 19'',eibach pro kit,bilstein sport,magnaflow,K&N,Giac,Rai TP, Vent Awe,Hitachi-E,034 street density,full ABT,RS4 sway,EuroGear Boser..ect...ect
    Veteran Member Three Rings zamflip's Avatar
    Sep 21 2010
    Bayliner 175, 2014 JGC wk2, and wifey s40
    Smithfield, ri
    I cant see any pictures, all i see is... "the photo or video has been deleted or moved"... so desperate to see those pics... yep, my glovebox fell on my gf's shins but lucky that she still loves me :P
    Jan 14 2011
    Edmonton
    Hi could you some how repost the pictures on how to remove the glove box door? i kinda need to take off the box door and fix the hinge
    Veteran Member Four Rings ocod's Avatar
    Feb 17 2009
    05 A4 1.8TQM, 05 Nissan Xterra, 99 Sea Doo Sportster
    miami
    KO4 APR Stage II+ // tt injectors // Podi SW gague // NGK BRK 7E .28 gap // 2.5" Test Pipe // Forge 007 DV //
    APIKOL Snub Mount // Stock N75 // 20%Tint // DTH FRP Skirts // 270 miles to empty // B7 key fob // 35W 5K HID's
    Apr 16 2011
    Cumbria, England
    For anyone who is trying to complete the fix, I found that if I went to the OPs photobucket page I was able to find the original photos.
    Here is a link http://s252.photobucket.com/albums/h...ket/?start=all, not sure what order the photos need to be in but it seems to help as a reference guide.
    Active Member One Ring Audeeznuts's Avatar
    Feb 14 2011
    MASS
    Thanks PCYC for your extensive diy. I did this bracket mod and took some sand paper to the oring on a 04 S4 we got. Works great and saved me some money. Thanks!
    If It Doesn't Have Tits, Trigger, Or A Throttle I'm Basically Not Interested
    Big Trucks Fast Cars
    Sep 10 2011
    None
    REPOST THE PICS!
    .....please? I asked nicely. :)
