Results 1 to 40 of 54
    Senior Member Three Rings Grassmonkey's Avatar
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    Non S-Line RS4 grill installed
    Yep thats right, I got 1 to fit and no this is not a photochop!!
    Here are some pics of it installed on my DTM
    and a close up of the grill
    and some pics in the snow here in Swiss, unfortunatly its already late so the light is not great, and the car is dirty, but still enjoy..
    Non S-Line RS4 Grill DIY Guide
    Parts needed:
    1x RS4 grill: 8E0 853 651 L 3FZ (Brushed Alu trim)
    1x Non S-Line grill : 8E0 853 651 J 1QP (Chrome trim)
    1x RS4 adapter: 8E0 807 083 A
    1x RS4 Euro Plate Holder: 8E0 807 285 AT 3FZ
    Note this is with a euro front plate, dimensions 520x110mm
    Using your old grill is possible but this does take some time + I didn’t want to screw up the parts already on my car.
    Tools needed:
    Body Filler/ Modeling putty
    Duplicolor mat black plastic spray can
    Epoxy glue, super glue
    Wire cutters, clamps, flathead screw drivers, sandpaper, Dremel
    Right now what the problem is, is that the RS4 grill continues on down too far + at the bottom is narrower than the NSL (non s-line) because of its length. So what needs to be done is that the bottom bit of the NSL needs to be attached on the RS4 at the right height.
    How to get on with this is to first remove the trim. The side and bottom clips can be individually unlatched using a screw driver. All of the top clips however are a pain, these will only come out if all are removed at once. I used several old cutlery knives to stick between the clip and the trim and once all are in with 1 pull the trim is off. You do not need to remove the Audi rings.
    Now the incision needs to be made underneath the plate holder, and for the NSL between the bottom 2 side screw holders, where the bumper attaches. Now the cut ideally needs to be that same distance from this top screw holder for both grills. This will mean they are “flush” when the 2 mate. I say flush because the NSL grill rim is thinner than the RS4, so filler will be needed here.
    The NSL bottom piece is removed, only the rim is needed as this is what is needed for the trim and bumper to attach to. The vert. + horizontal latches can be removed. This leaves several holes and unevenness. This is the most work, getting the bottom bit of the NSL to look flush again. Furthermore the NSL grill is not the same color as the RS4, I used Duplicolor’s mat black plastic spray paint and it matched perfectly.
    Cutting the RS4 grill your priority is to have the honeycomb undamaged, now the best way to do this is to cut the rim of the grill at the honeycomb endings. This gives some buffer material to get a good connection with the NSL piece, and sanding is easier to do than adding more stuff, I know now from experience.
    Now for the fit you need to have 3.5 layers of the honeycomb left over, for perfect fit a little more. I did this so that it would look good, and was close enough to what is needed, but if you look at the installed pics at the top of this post, you can see that there is a slightly larger than normal gap, but Im satisfied with that. This is cause the bottom is slightly rounded and not straight, which i didnt assume but tried to get when cutting and glueing.
    Make sure everything is sanded nice and smooth because with the mat black paint on unevenness is easily spotted. Take time to make sure every piece is looking good before you put it all together because it wont look nice otherwise and takes more time to correct later, I imagine.
    Now using epoxy I glued the NSL piece top the rim of the RS4 grill, and used super glue to glue the honeycomb to the NSL piece. Now some more filler is needed to get a good flow from the RS4 grill over to the NSL bottom piece, and to get the honeycomb/NSL piece connection looking good. Then spray to get everything the same color, attach the trim and install.
    Now this was how I did it. It is rather a complex thing to do. Measure up the distances for the screw holding points on the grills so that this matches up later. When test fitting the bottom piece, it is important that you use the trim as guide, cause if this doesn’t fit your grill wont work! I test fitted the NSL piece without the trim and ended up cutting more away then needed, which cost me a lot of time to put right. Also the NSL has 1 central mounted clip that attaches to the cars frame, the RS4 has 2, I found this out when I was installing the grill, I cut them off and the grill holds fine.
    Its not an easy mod to do, it costs a lot of time. What is written here is a guide not a must do. Use whatever ways you think best to achieve the goal of a NSL RS4 grill. This just shows that it can be done!
    And no I will not be making or selling any!
    2006 B7 A4 DTM
    Mods: RS4 Pedals, RS4 side mirrors, RS4 grill, S4 Blades, PSS9's, RS4 rear swaybar, 034 HFC, Milltek Exhaust, ATP GT28RS, S3 Injectors, HPFP, Rennworx RSL 19x9
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    Re: Non S-Line RS4 grill installed
    Oh yeah and I did the clear corners at the same time too!!
    2006 B7 A4 DTM
    Veteran Member Four Rings onkloud9's Avatar
    Sep 07 2005
    Golf R
    San Diego
    Very nice Matches the fog inserts pretty well.
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Nicely done.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Deactivated Three Rings Coker Rat's Avatar
    06 2.0T A4 w/quattro
    Fort McMurray, Alberta
    very nice
    Veteran Member Four Rings gods_kitchen's Avatar
    Good job!!
    Senior Member Three Rings so.cal.sparky's Avatar
    Oct 12 2006
    Moorpark,CA-Ventura county
    Very nice wright up thanks for all the part numbers also. got more mods added to my list now
    Senior Member Two Rings mill1246's Avatar
    Sep 17 2006
    Grand Rapids, MI
    looks great
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    awesome work, nicely done.
    Veteran Member Four Rings A4TwoZeroT's Avatar
    Aug 03 2005
    San Diego, CA
    sick!
    Veteran Member Three Rings mrponline's Avatar
    Sep 18 2006
    2008 Audi S5, 2007 VW Golf R32
    Sydney Australia
    Well done
    2008 Audi S5 6MT
    Phantom Black, 20" Forged DPE 3 Piece Wheels, Nitto Invo 285/25 Tyres, H&R Suspension
    2007 VW Golf R32 6MT
    2006 A4 2.0T Quattro 6MT Sline - SOLD
    Veteran Member Four Rings bunnn's Avatar
    Jan 24 2006
    e92
    hmm looks good..what would have been even better is if you had the black optic trim on the outside...cause you seem to have a little black/cf theme going..
    Cheers!
    ~Ben
    Veteran Member Three Rings FlashA4's Avatar
    Dec 17 2006
    Formerly B7 A4 2.0T - The OG Flash Mobile / B8 A4 2.0T Quat - Baby Flash
    Orlando, FL
    im very impressed at your ingenuity and even more at your willingness to cut it in the first place!
    great job.
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Nice !!
    DUH! an Audi
    los angeles, CA
    nicely done, i had an idea sorrta like that...I need to get a new front bumper (aftermarket) then fit the rs4 grill hehe
    Veteran Member Four Rings A4_cabrio's Avatar
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    Awesome work - your front is HOT and unique
    2005.5 2.0T Tip Dolphin Grey / Black Interior
    Factory options: all except for Bose sound
    Added: 35% Tint, OEM Bluetooth, MFSW with paddle shifters, RS4 pedals, Brushed Aluminium mirror caps, S-line bumper, RS4 grille, Euro plate filler, 19" RS4 reps (Velocity), S4 valence, Satellite receiver, Quad tips, VMR boost gauge, AUX port
    Next mods: honeycomb fog grilles, LED DRL, Dension
    Dec 27 2005
    New Orleans
    car is hot!!!!!!!!!
    I wanted the black rs4 grill and didnt think it was possible to fit it on a non sline so i went and bought a sline/s4 bumper...hahah makes me wish I shoulda went dtm instead.
    Veteran Member Four Rings TDI's Avatar
    Nov 13 2006
    a4 avant B7
    Belgium
    lovelyyyyyyyyyyyyyyyy
    -God show me the way..because the devil try's to break me down-
    Kanye West
    Registered Member Two Rings
    Sep 17 2006
    Thailand
    Neat!
    Sep 14 2006
    Arizona
    Awesome, great job
    Senior Member Two Rings 1SICKAUDI's Avatar
    Feb 03 2007
    Michigan
    Looks sick
    Veteran Member Three Rings lucifer's Avatar
    Sep 22 2006
    Long Island NY
    looks awesome man, great work...wish i had the patience to do that...my ocd would kick in and id be adjusting it for the next month or two before i got it perfect...and id probably destroy it in the process lol
    jeden Tag im drängend
    << FORMERLY COWMON2 >>
    2012 A4 2.0T 6MT/ Brilliant Black/ Black Leather/ Premium Plus/ Sport Pkg./ Navigation Pkg./ Chrome Exhaust Tips/ 35% Tint
    (2006-2011) 2006 A4 Quattro 2.0T 6MT/ Brilliant Black/ Ebony Leather/ Sunroof Pkg./ Premium Pkg./ Sirius Sat/ 35% Tint/ 18" VMR RS4 Rims/ Carbonio Intake
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    Quote Originally Posted by lucifer View Post
    Exactly! Very well done. I wish someone would start mass producing these for the non-slines! I'd buy one in a heartbeat.
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
    Registered Member Two Rings vdubmurray's Avatar
    Dec 28 2006
    07 A4, 84 GTI, 03 GTI
    Kingston, PA
    Now it looks correct compared to the stock DTM grill. Nice job!
    Senior Member Three Rings kak39's Avatar
    South Jersey
    Leave it to the swiss to do such an amazing job reworking that grill. Nice job
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    Well then that would be, Dutch made, Swiss Installed.
    Just got back to the Netherlands from Switzerland, through autobahn country!!
    Love the look of the car, but its a little too much show and not much go at the moment! Gonna have to hook myself upto a stg3 soon!
    And I was split about wheather to go with chrome or black trim, but i think the chrome is nice buffer between the silver and black.
    2006 B7 A4 DTM
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    Quote Originally Posted by Grassmonkey View Post
    i agree on that.
    in ur signature it says u have pss9's. Why so high!? dump that shit itll look hott
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    whoa talk about a dead thread resurrect!
    Established Member Two Rings Eldritch's Avatar
    May 02 2007
    https://www.garaget.org/?car=416218
    Sweden
    Very nice job you have done
    Veteran Member Three Rings wflan's Avatar
    Jul 07 2007
    worth it... hot car!
    Boulder, Colorado
    2007 Red A4 2.0Q MT w/ Premium Package, apr91 and sticky shoes.
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Quote Originally Posted by A4ItaliaGT View Post
    i agree on that.
    Prolly raised it due to the weather conditions (at the time of photos).
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Aug 18 2007
    Audi A4 2.0T MT6
    Fort Myers, FL
    nice job......looks awesome!!!
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    woaahh... been digging in the past!!
    Those pics were from before I had the PSS9's.
    Here are some from a while ago but with the bilsteins.
    http://www.audizine.com/forum/showthread.php?t=127458
    2006 B7 A4 DTM
    Feb 09 2007
    Killeen, TX
    looks great !!!
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Active Member Two Rings Narbo's Avatar
    Jul 29 2007
    Glendale, CA
    wow, creative work... im going to keep you in mind for my next cusstom work
    * 997 C4 Cab // 19" Work wheels, techart susp,exhaust, fabspeed headers, big reds.
    * A4 B7 2.0T // 19" RS4 reps, Koni Coilovers, Neuspeed ECU. Supreme Power FMIC, Taillight reverse delete.
    * E36 M3 // Supercharged, intercooled, Hartge wheels, Dinan suspension, Remus Exhaust,
    * Audi Coupe GT '86 // 17" Antera 101's, Bilstien shocks, H&R springs. supersprint exhaust.
    Nick Zohrabi
    Aug 05 2007
    07 A4 2.0TQA
    Charlotte, NC
    big bump, wondering if anyone else has since tried this? any way to get the missing pics from the write-up?
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    i cant wait to get mines...sweet!!
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    there is now a company that sells non s-line RS4 grills, its eurotechnik
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    Quote Originally Posted by 704b7 View Post
    Sorry about the pics, but since Audizine went to a 5mb limit on the gallery I've been deleting older ones so I can add new ones.
    John Strathman made an RS4 grill fit on his DTM bumper about a month ago. He mostly posts on AW, although I did see him here I think.
    2006 B7 A4 DTM
    Aug 05 2007
    07 A4 2.0TQA
    Charlotte, NC
    Quote Originally Posted by nsmith12 View Post
    do you have their website or contact info?
    sorry, i looked and couldn't find it
