The skill level is about a 5/10 with soldering ability needed.
10 = Master tech
5 = Average Garage monkey
1 = 10yr old son's ability
The equipment you'll need is:
+Wire Cutters
+Pliers
+Soldering Iron
+Solder
+18-20 Guage wire (12 inches total)
+2 100ohm-150ohm 5W-10W ceramic coated resistors
+Heat shrink (various sizes)
+4 squeeze connectors
Start off by cutting four 3" wires. Strip only one end of each wire to expose about 1/2" of wire. Then trim the resistors so that only about 1/2" of the wire coming out of each end of the resistor is showing. Next wrap the wires around the ends of each resistor.
Next solder the wires to the resistors.
Next cut some heatshrink and use the base of the soldering iron to heat up the heatshrink.
Next cut some larger heatshrink and shrink it over the Resistor.
Next use the pliers to clamp the wire squeeze connectors onto the BLACK and GREEN/WhiteStripe wire on the LED Tail Lamp. The Black wire is the ground wire and the Green/WhiteStripe wire leads to the LED's for the running light. The wires are the same for each tail lamp.
Now you're done.
Here's what the Running Lights look like installed on the car with NO Bulb Out Error.
With Brake Lights on:
With Hazards on:
