Page 13 of 36 FirstFirst ... 3111213141523 ... LastLast
Results 481 to 520 of 1433
  1. #481
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by elscotto80 View Post
    After using the new UI, I have some questions. The steering wheel scroll is nice, however i think there is an unintended consequence. For example - when in the main UI it will scroll through the various menus/options/apps, however I wouldn't want it to because I would be using the wheel roller to switch stations in sirius or FM and when scrolling through my recent calls to make a BT phone call with the OEM BT (sorry the android BT is not as good as the OEM system. No-one can hear me when I use it). I noticed a new menu to check and uncheck various button functions and i suspect I will have to do this to avoid the system scrolling when i really don't want it to as i will lose the wheel scroll. Is there a work around or was this by design? If this is how its going to be then the new UI wont be that useful if you don't plan on using the factory radio.
    I have also noticed a bug earlier today where it would open the OEM interface and when i went to touch the screen to go to the android UI, it would quickly switch back to the OEM screen. A restart seems to have fixed this.
    Why are there so many bugs/restarts when an update is applied? Maybe I am in the minority because I have one of the original units. Should we be doing a factory reset of the entire device when these updates come out?
    1. I have to check if there is way to suspend the button signal input when the radio is not in aux. Meanwhile, it you don't want to steering buttons just uncheck it. They will stop working. Also you can still use the launcher of your choices.
    2. Maybe your mic board is faulty. Myself, i disabled the factory BT, and have no issue on our bt with my pixel xl. (Indeed i think voice call volume is a bit too quiet.)
    3. Did you disabled parkimg key in the realsun setting?
    4. I think you may better to send it back to us and have a replacement. It's the same hardware, but many thing were added as vents, heatsink, 3.5mm audio output.
    However, it is recommended to fo a factory reset after update, as android builds up entropy when update over existing apps(consequence of so called the dirty install).
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  2. #482
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    Quote Originally Posted by a4android View Post
    They are meaningless stuff for you. The mirrorlink was to trigger easyconnected and safe was for external tpms system access through aux2.
    Ok. I have the easyconnect app and thought there was a specific hotlink for that.
  3. #483
    Jan 03 2013
    Baltimore
    I plan on playing around more today and do a factory reset to see if this solves some issues. If things still persist, i'll get in touch with you about a replacement and we can go from there.
    I should be able to add to the wiki regarding menu translations today. Hopefully that can be applied soon to really refine the unit. Also need to figure out why climate controls do not show up when i adjust the temp.
  4. #484
    Jun 08 2015
    Montreal, QC
    I think canbus decoding software thingy may be act weird these days, such as coming and going parking guidelines.
    All the resolution same models use a identical software, and they debugged the software on a 2012 mmi vehicle recently, whereas they debugged based on a concert car before. Maybe this is why... But I am not sure.
    Expecting the publication of the source codes give us more insights.
    It's always not easy to get the best of all world, i guess.
    Daniel Kim
    2012 A7 C7
  5. #485
    Mar 31 2017
    Spanishtan
    Climate controls show up correctly for me, apart from the Chinesse text.
  6. #486
    Jan 03 2013
    Baltimore
    What are you referring to by disabling the parkimg key? What does it do enabled and disabled?
  7. #487
    Jun 08 2015
    Montreal, QC
    Disabled. If already done, perform factory reset. I will also check if there is canbus update for concert as those are related to canbus.
    Daniel Kim
    2012 A7 C7
  8. #488
    Jan 03 2013
    Baltimore
    Quote Originally Posted by grabie View Post
    Climate controls show up correctly for me, apart from the Chinese text.
    Nothing shows up now for me. Hopefully a factory reset fixes this.
    As I have mentioned a few times, adding seat heater popup would be nice as well.
  9. #489
    Jun 08 2015
    Montreal, QC
    Seeing we are able to catch that event from the clima can bus line. No outcome yet.
    Daniel Kim
    2012 A7 C7
  10. #490
    Jan 03 2013
    Baltimore
    When you disable the left wheel key, there is no way to scroll through the apps from the "app" icon on the new UI. Basically, you need to enable it and switch the "home" in android from the new one to google now in order to get into native android. There should be arrows in the app list to scroll like there are in other menus in the realsun settings.
  11. #491
    Jan 03 2013
    Baltimore
    I added an extensive list to the wiki page regarding menu translations. Please take a look and provide feedback.
  12. #492
    Dec 30 2011
    South Africa
    Download
    This is the ugly set of the original images, and you can edit it by yourselves according to the specification of the image files.
    The reference one is A4L.
    If you'd like to add your custom image, just let me know the title of the image type to be displayed in the realsun setting, and send your image to [email protected]
    Meanwhile, I will try to update the app itself to be customizable on the device.
    Created a new one for the A5 image as the one currently isn't very good quality. But it would be awesome to have the ability to choose a custom image in the realsun settings
  13. #493
    Oct 10 2016
    Madrid, Spain
    It would, especially given that you can get the specific image of your own car on audi.com
    Sent from my SM-G935F using Audizine mobile app
  14. #494
    Jan 03 2013
    Baltimore
    Quote Originally Posted by whity View Post
    An option to pick an image from the gallery.
    Sent from my Pixel using Tapatalk
  15. #495
    Jan 03 2013
    Baltimore
    I still do not know what parkimkey is. Can you elaborate or tell me where it is in settings? I did the factory rest and it seems to be much better. However u cannot use the new UI due to the rollers having unintentional clicks when using Sirius, etc. There isn't a way the scroll the app list without the rollers. Need to figure this out.
  16. #496
    Jun 08 2015
    Montreal, QC
    Eh... If you drag the screen with your finger... You can go further down. It's not like the ui doesn't support touch...
    Parking key is in the realsun setting, further down.
    Daniel Kim
    2012 A7 C7
  17. #497
    Jan 03 2013
    Baltimore
    The touch was not working at all to scroll down, I tried.
    What does parking key do? Why do I want it enabled or disabled?
  18. #498
    Jun 08 2015
    Montreal, QC
    That's not normal eh... Is your touch completely dead at all?
    The list should go down when you drag a finger from top to bottom. Downward.
    Parking key is something available with the oem reverse cam that you can monitor the rear even before you shift to reverse.
    For cars without this, if the setting is enabled, then it would cause erratic behavior that the ui keeps switch back to oem screen regardless of your command every few second until you restart. From the new firmware, it has been disabled by default.
    Daniel Kim
    2012 A7 C7
  19. #499
    Jun 08 2015
    Montreal, QC
    By the way, it's park radar key.
    Daniel Kim
    2012 A7 C7
  20. #500
    Jan 03 2013
    Baltimore
    Touch screen works fine, but in that location of "apps" pulling up or down does nothing. There are no arrows to push either like in other menus. I'll have to look again for this parking key and see whats what.
  21. #501
    Jun 08 2015
    Montreal, QC
    That's really not normal.
    As if you scroll up and down on your pixel to browse, it should respond the same. Put a finger intact and drag up and down should make the rectangular selection changes accordingly. Try the usb to usb method like before. There is the recovery kit in the wiki(dev. Resources).
    Meanwhile, i will discuss to have arrows in that app picker.
    Daniel Kim
    2012 A7 C7
  22. #502
    Mar 31 2017
    Spanishtan
    Did you try sliding your finger from the bottom to the top of the screen? Obvious, I know.
  23. #503
    Jan 03 2013
    Baltimore
    Just tried and now it seems to be working. Its not really intuitive to scroll like that, but it is what it is. As I noted before there were tons of reboots and restarts when this was applied, so it looks like things have finally smoothed out.
    I am not using the new UI as its not going to work for me. There needs to be some more refinement to be able to change the iNav hotkey (to open any app you want) and ignore the wheel scroll when trying to operate the factory interface without disabling it completely in settings. I like the "look" of the new UI, it is much better suited for use in a car compared to the previous one.
    There should be some options to be able to change what shows up in the main menu. Example - the AUX in. I have nothing hooked up here so its a useless icon. I am sure I am not the only one with nothing added as a secondary input.
    Sorry to sort of bash, but there are some things that still need a little more work.
  24. #504
    Mar 31 2017
    Spanishtan
    Agree 99% as I´m using the new UI instead of carwebguru. Just because of the OEM look and wheel control, as CWB offers much more personalization options.
    Yes, some more detailed work is needed, but the software is improving fast. That´s why I think wiki is a very good option to let Daniel know what´s right or wrong... I´m aware you are contributing, me too.
  25. #505
    Jan 03 2013
    Baltimore
    I think the software is about "there" and is really usable right now. What needs to be worked on is the appearance and layout of the overall system. Some menus are not easy to understand what they do and do not follow the same style as the previous ones.
    It will get there, i have no doubt!
  26. #506
    Jun 08 2012
    N Massapequa, NY, USA
    My complements to Daniel for the improvements to the product, the RSNAV website and being willing to setup and host a wiki page on his website. Further kudos to the RSNAV community for committing to updating the wiki. I am really excited that we have a viable user-supported product to upgrade our great vehicles.
  27. #507
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by DennisMitchell View Post
    Thanks,
    but, the wiki is set up and hosted by Audizine member d3mon187.
    I just linked the wiki to my website and maintaining it.
    d3mon187 is the person who should get compliments.
    Daniel Kim
    2012 A7 C7
  28. #508
    Junior Member One Ring
    Jan 24 2018
    Baltimore, MD
    Anyone using the "Android Auto/AutoPlay" dongle?
    I've update my 7" unit with all the recent firmware updates (Android and MCU) but when starting "AutoPlay" it prompts what to do with the USB device (which I assume is the dongle) When I select "make this the default" for the device it just keeps prompting me, everytime I start AutoPlay. Not impossible to deal with, but seems like if it asks me to make a permanent decision it should remember it...
  29. #509
    Jan 24 2018
    Baltimore, MD
    BTW, I'm on the Concert version...
    Quote Originally Posted by carlmuck View Post
  30. #510
    Nov 17 2012
    Guernsey
    Ditto but so far I just deal with it. It’s a minor thing so I haven’t personally taken the time to put it on the bug list yet.
    Current
    Audi R8 V10+ DSG in Ibis White, blk lthr interior - Tubi Style exhaust
    Audi SQ5 in Glacier White
    My YouTube Channel
  31. #511
    Nov 27 2017
    Odense
    The only issue left is the BNAV resolution sync, but we were not able to acquire working BNAV unit yet, so still looking for BNAV head unit to purchase. There are some in Ebay, but the price is insane.
    Could you elaborate on what the issue is?
    If it's just a question of tweaking video sync frequencies or whatever to get the passthrough working, I could maybe help with that if the hardware is otherwise functional and those settings are somehow accessible, even if it's a firmware thing (provided there's a mechanism for updating the firmware without JTAG etc.)
  32. #512
    Mar 31 2017
    Spanishtan
    Trying to figure out how to reassign the apps which are linked with different icons in the new user interface I thought that maybe uninstalling, lets say, MX Player, the system would ask for a new music player app to prompt when pushed the "media" icon.
    Would this "hack" work?
  33. #513
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Have you applied the updated apk for the dongle?
    I don’t use ACP that much, so can’t remember if that resolved that after applying the new apk. I’ll try it tonight.
    Also if the apk isn’t on the site/wiki, I’ll see if I can add it tonight.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  34. #514
    Jan 19 2018
    May be a dumb question.. can't find the answer, but what is the best way to remove the screen frame (black) from the original silver bezel?
  35. #515
    Jan 03 2013
    Baltimore
    Quote Originally Posted by stephenhanlee View Post
    Get some needle nose pliers and start breaking it carefully from the silver bezel. You will see welded tabs that you need to break it off from. Just be careful and slow.
  36. #516
    Jan 24 2018
    Baltimore, MD
    It is impossible to tell if the update is an update. That being said. I have downloaded the latest from the link in the wiki and it didn’t update anything so I assume I’m on the latest version.
  37. #517
    Mar 31 2017
    Spanishtan
    Let me quote this post that will help you:
    I did the following
    1. Copied update.zip to my USB drive,
    2 .plugged it in the unit.
    3. Brings up the update code to be entered cancelled that
    4. Copied update.zip to SD card and Internal storage root.
    5. Unplugged the USB drive and plugged it in
    6. Brings up the update code and you enter '888666'
    After the update of about 30min and multiple restarts
    1. Delete update.zip on USB drive, SD card and internal storage root.
    2. Copy mcu_update.bin to USB drive
    4. Copied mcu_update.zip to SD card and Internal storage root.
    Again let the unit restart a few times, but its a lot quicker
    And finally delete the zip files from all of the storage locations to clean up
    So you need two different files to aply: update.zip (1 Gb) and mcu_update.bin (several Kb). Follow the instructions step by step and everything will be ok.
    Besides, take into consideration that the update takes several reboots to take effect... so be patient.
    - - - Updated - - -
    Bump!
  38. #518
    Established Member Two Rings Sharkonholiday3's Avatar
    Dec 26 2017
    Italy
    - - - Updated - - -
    Bump!
    Hy guys.... What is mcu_update and who have to apply???
    I have 7" with concert and can bus.
    I have update only new firmware and not mcu.... I have to do???
    Thanks
    Inviato dal mio SM-G950F utilizzando Tapatalk
  39. #519
    Jan 19 2018
    Any recommendations on screen protectors for 7 in?
    Sent from my Pixel 2 XL using Audizine mobile app
  40. #520
    Mar 31 2017
    Spanishtan
    Quote Originally Posted by Sharkonholiday3 View Post
    Thanks
    mcu_update file is available on RSNAV.com / downloads
    First apply update.zip, then mcu_update.bin
    That´s how I did it and worked fine.
    I´m not using any.
